Results 1 to 4 of 4
    New ROGer Array
    Aug 2015
    4
    Lost LN2 jumper switch HELP
    I lost my ln2/switch and since I don't use ln2 I'm worried now without it that I can't disable it? Can I get a replacement somewhere ? I looked but had no luck.
    Thanks
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,548
    how do you loose a switch that's soldered on the board?
    ROG Guru: Green Belt Array Dr. Zchivago PC Specs
    Laptop (Model)Lenovo Thinkpad T410
    MotherboardASUS Crosshair V Formula - Z
    ProcessorAMD FX 9590
    Memory (part number)BLE2KIT8G3D1869DE1TX0 (8-8-8-24, 1866 MHz)
    Graphics Card #1ASUS R9 390 STRIX (OC, GAMING)
    Storage #1SG Constellation 6 TB (6x1 TB) RAID 0
    Storage #2SG Constellation 2 TB (2x2 TB) RAID 1
    CPU CoolerNoctua NH-D15
    CaseCaseLabs STH-10
    Power SupplyCorsair AX1500i
    Keyboard Microsoft Sidewinder X4
    Mouse Microsoft Sidewinder X5
    Headset Logitech G930
    Mouse Pad Perixx 900x440x3 mm + Steelseries 320x270x3 mm + ALLSOP hard pad
    Headset/Speakers Logitech G930/Altec Lansing 5.1
    OS Windows 8.1 Pro (64 bit)
    Dr. Zchivago's Avatar
    Oct 2013
    66
    609
    Quote Originally Posted by Menthol View Post
    If it's a pin-to-pin jumper, then you can just use a small metal clip until you find a replacement. Perhaps an old Master/Slave/Cable jumper from an IDE HDD, if you have one? The spacings are generally similar enough to make little difference.
    Z
    Resistance is futile (at <1 Ohm).
    ROG Guru: Yellow Belt Array
    Nov 2015
    154
    Try Googling it you never know there maybe a supplier that sells them in bags.
    Failing that contact Asus support directly they maybe able to assist you.
