01-04-2016 11:16 AM - last edited on 03-06-2024 02:55 AM by ROGBot
01-04-2016 11:34 AM
01-04-2016 11:35 AM
01-05-2016 08:49 PM
Korth wrote:
Rampage V Extreme motherboard manual here.
Ensure the motherboard power inputs are all properly connected. Also connect the optional EZ-Plug if you're running high-end or multiple GPU cards.
Clear CMOS and attempt to boot with BIOS on factory defaults. Do not tweak or overclock anything until your hardware can boot and run stable at defaults.
Q-Code 67 indicates "CPU DXE initialization is started" (but system halted before System Agent DXE and PCI host bridge initializations have started). This suggests to me that your processor is defective or improperly mounted. Or your PSU is woefully underpowered for boot-time surge demand.
Can you list your complete system hardware specs and BIOS firmware version? Is your DDR4 compatible with X99 and listed on the R5E memory QVL?
01-05-2016 12:26 AM
01-05-2016 09:11 PM
01-06-2016 08:55 PM
Korth wrote:
I would try running the system with a standard JEDEC-2133 profile, just to eliminate memory issues. Probably best to run a full memory burn-in/stress test with each individual DIMM (then with all DIMMs populated) to confirm none are defective.
If memory isn't an issue then it seems likely your i7-5930K isn't properly mounted. It's a hassle (and a waste of TIM), but it might be best to completely remove and remount it, checking carefully for any bent pins and obsessing about exactly correct pressure when remounting it. An electrical contact cleaner (like Stabilant-22 or DeoxIT) can make a huge difference on dirty or oily pins, but it won't make much real difference on chemically clean parts.
01-07-2016 02:57 AM
01-12-2016 10:32 AM
