Results 1 to 5 of 5
    New ROGer Array
    Jan 2016
    3
    Exclamation G750JM GPU Tweak problem
    Hi guys.
    I hope somebody can help me. I bought an SSD to my G750 then we reinstall the windows 10 everything good but the GPU Tweak does not work as it used to before. Now the program dont show the RPM speed and when i turned on, it dont turn on the fans...
    I downloaded the program from ASUS but for win 8.1 because they hasnt got the tweak for win 10.
    Thanks your help!
    ROG Guru: Yellow Belt Array
    Jun 2014
    12
    177
    Use MSI Afterburner instead...
    http://gaming.msi.com/features/afterburner
    Laptop: Asus G750JZ
    OS: Win10
    New ROGer Array
    Jan 2016
    3
    THX i did but the same....
    I think something else missing.
    Jun 2014
    12
    177
    Sorry about that. I forgot Afterburner fan control doesn't work w/ the G750. What does work is v1.4.2 of Notebook FanControl...
    https://github.com/hirschmann/nbfc/releases
    Use the Asus M52VA config, and in the Settings menu select Start with Windows, and Minimize/Close to tray. You can also try the ASUS Zenbook UX32LN config. for controlling both fans.
    Laptop: Asus G750JZ
    OS: Win10
    New ROGer Array
    Jan 2016
    3
    Thank you! Its work.
