Results 1 to 7 of 7
01-08-2016 11:28 PM #1
- Join Date
- Dec 2015
- Reputation
- 10
- Posts
- 10
where I can purchase a replacement battery for gl551jm-eh74?
Does anyone know where I can purchase a replacement battery for this laptop? It's 1 year old and I cannot find it anywhere
01-08-2016 11:42 PM #2
- Join Date
- Jan 2013
- Reputation
- 100
- Posts
- 2,237
fyi. Probably something you prefer to avoid and hopefully others have better suggestions, but if you didn't already know, you can always send it back to ASUS for (out of warranty?) service later if you can't find better options.
http://www.asus.com/support/callus
If you still have a copy of your invoice, you might also want to check if you can still get warranty service as well.
01-08-2016 11:44 PM #3
- Join Date
- Dec 2015
- Reputation
- 10
- Posts
- 10
yes i called them and they told me to rma it but i hear horror stories about the time it can take. I also don't understand why they wan't my whole laptop sent in if they already know the battery I need
01-09-2016 12:08 AM #4
- Join Date
- Jan 2013
- Reputation
- 100
- Posts
- 2,237
Sorry, if your unit has an external/removable battery, we probably did not realize this.
You might want to make sure the call center is aware of this, but unfortunately, our repair department is not set up to sell parts although if you don't mind sending back your battery only for RMA (make sure nothing gets near the exposed battery contacts of your notebook while you are waiting), that's another idea.
Otherwise, if you are located in the U.S., you can check if the ASUS Store or U.S. eStore site is able to sell this part.
http://us.estore.asus.com/
http://store.asus.com/us/
We don't have a lot of notebooks with removable batteries these days, so apologize if we missed this and something you may want to remind us about.
Thanks and good luck!Last edited by cl-Albert@ROG; 01-09-2016 at 12:12 AM.
01-09-2016 02:00 AM #5
- Join Date
- Dec 2015
- Reputation
- 10
- Posts
- 10
Actually I think I figured the problem. My ac jack was broken so I had to get it soldered, but the guy soldered in a charger part that didn't work with my ac adapter so he gave me a charger that is 40 watts when my laptop requires 56 watts.. so I am going to tell the repair dude this and hopefully get a refund and buy the right charger.
01-09-2016 02:46 AM #6
- Join Date
- Jan 2013
- Reputation
- 100
- Posts
- 2,237
Ah, glad you could figure that out and wondering why your battery went bad that quickly.
I believe the GL551JM should be using at least a 120W charger (19V, 6.3A) though like the GL551JW, so you may want to check that as well.
There is a label under your notebook which will list the charger input requirements (19V, 6.3A), so you can check it without having the original charger around.
01-09-2016 03:38 AM #7
- Join Date
- Dec 2015
- Reputation
- 10
- Posts
- 10
wow it is 120w, how could this guy sell me a 40w charger.
http://imgur.com/8PJbmQd picture of the chargerLast edited by Vethosis; 01-09-2016 at 03:47 AM.
