Results 1 to 4 of 4
01-10-2016 11:57 PM #1
- Join Date
- Nov 2015
- Reputation
- 10
- Posts
- 33
How to easily check G751JY fan speed? - solved
I have a G751JY and would like to check whether my CPU fan is running. I installed Speedfan 4.51, but while it gives me CPU temp, it doesn't show fan speed even when the cores are over 45C. Does anyone know of any way I can easily get fan speed. I just want to make sure the fan is actually working.
01-11-2016 12:34 AM #2
01-11-2016 06:04 PM #3
- Join Date
- Nov 2015
- Reputation
- 10
- Posts
- 33
Thanks for your help. Works like a charm. Now I can see fan speed, Don't know why Speedfan wasn't showing fan speed. Could be a Win 10 issue.
09-27-2016 10:37 PM #4
- Join Date
- Nov 2014
- Reputation
- 10
- Posts
- 14
HWMonitor no longer showing fan speed on G751JY
HWMonitor used to show fan speed, but no longer does so.
Not sure exactly when this stopped. Could have been a bios update, a driver update, a HWMonitor update or a windows update.
Tried regressing HWMonitor all the back to 1.27, as that is the only thing i really have control over.
Anyone else has this problem or know how to start looking for how to fix it?
