01-13-2016 06:05 AM - last edited on 03-06-2024 03:07 AM by ROGBot
01-13-2016 06:14 AM
01-13-2016 06:14 AM
01-13-2016 06:18 AM
Nate152 wrote:
Hello LethalTiger and welcome to the ROG forum.
Check to see the slow mode switch on the motherboard is switched to off.
Also try setting the windows power plan to high performance I think you need to do this for the magician software for Samsung ssd's.
01-13-2016 07:16 AM
LethalTiger wrote:
Did that and cleared the CMOS and there is no slow switch on the motherboard.
01-13-2016 03:17 PM
Chino wrote:
Correct.
Please look for the LN2 Mode jumper that's near the last PCIe slot and make sure that it's in this orientation.
01-13-2016 06:09 PM
LethalTiger wrote:
I changed the LN2 jumper which is for liquid nitrogen and no difference.
01-13-2016 06:21 AM
01-13-2016 06:29 AM
01-13-2016 03:20 PM
InfernoStorm wrote:
That's odd, there was someone else recently that had the same problem but I can't seem to find the thread but he was able to solve it.
Maybe try updating the BIOS to the newest one and see. Have you tried going into advanced power settings and changing the minimum processor load to 100% and see if it can actually run at the correct core clock? If even that isn't able to make it run at the proper clock then it's definitely something to do with settings in BIOS.
