01-15-2016 06:12 AM - last edited on 03-06-2024 02:57 AM by ROGBot
01-15-2016 06:41 AM
01-15-2016 05:21 PM
01-16-2016 06:53 AM
01-17-2016 09:16 PM
01-18-2016 04:08 AM
01-18-2016 11:32 AM
01-18-2016 11:49 AM
Mick1985 wrote:
I have a Asus VIII Ranger and im running G.Skill Model F4-3200C16Q-16GRK which IS on Asus's QVL but NOT on G.Skills QVL. I specifically got this memory because Asus's QVL shows that 4 sticks work. I only realized that G.Skill had a QVL after I bought the memory and I already took the heatspreaders off so I could put on EKWB waterblock. The memory does work after hitting a combination of MemOK and/or the reset switch and/or pulling the battery and or pulling the mem sticks and re-seating(which really sucks with the waterblock). I have gone through 2 motherboards and Ive run into alot of problems with it. First off you can forget about the XMP profile. It will not work and error 55 or 99. I have tried multiple bios updates with same result. I am so scared of trying to tweak it up to the 3200 because of these issues that ive kind of given up and am running at 2133 :(. Maybe the 1402 update will help.
01-18-2016 12:19 PM
NemesisChild wrote:
That G.Skill memory is a quad channel set designed for the X99 platform.
Go with the TridentZ sets since they are specifically designed for Z170 boards.
