Results 1 to 10 of 10
    New ROGer Array
    Jan 2016
    2
    3 Monitor 2 Graphics Card set up problems
    I have 3 x Asus PG278Q ROG Swift G-Sync monitors .
    I have 2 x GeForce GTX 970 Graphics Cards .
    I want to link all 3 monitors for gaming . The problem im running into is the cards only have 1 Display Port each so I have to connect the other monitor somehow . Ive used a Display Port splitter to connect 2 monitors to one graphics card . The problem I have is when its all connected the way ive described the 2 monitors connected to the splitter flash on and off continuously and the other one stays on as it should . Ive checked all monitors on their own and they work fine . Ive checked both graphics cards individually and they are both working as they should . Ive sent back the splitter for a new one after talking to the manufacturers incase it was a faulty one but its the same .
    Just wondering if any of you good people have any ideas .
    New ROGer Array
    Jan 2016
    2
    No replies ?? I thought this would be the best place to ask ..........
    ROG Member Array Cryowolf PC Specs
    Cryowolf PC Specs
    MotherboardAsus RoG rampage V Extreme
    ProcessorIntel I7 5960X ( OC to 4.5Ghz )
    Memory (part number)32Gb Hyper X Predator 3000Mhz
    Graphics Card #1Asus GTX 980 Ti Matrix Platinum
    MonitorAsus PB278Q/Asus RoG Swift pg279q
    Storage #1240Gb Asus RoG Raidr PciE SSD
    Storage #22Tb Western Digital Green HD
    CPU CoolerCorsair Hydro H100i
    CaseCorsair Carbide Air 540
    Power SupplyCorsair 1000W 80+ Platinum
    Keyboard Corsair Gaming STRAFE Mechanical Gaming Keyboard – Cherry MX Red
    Mouse Asus ROG Gladius FPS Gaming Mouse
    Headset Asus Vulcan ANC PRO ROG Gaming Headset
    Mouse Pad Asus ROG Whetstone Mouse Pad
    OS Windows 10
    Dec 2015
    8
    get a 980ti? or two...something with more dp ports...beyond that sorry no ideas using a splitter isn't the greatest solution, also 2 x 970 is a lil under powered for 3 2560x1440 displays especially ones that can manage 144hz.
    ROG Enthusiast Array
    Feb 2015
    29
    I think you need 3 cards for G-SYNC Surround.
    Edit: Three if they only have one DisplayPort each, because G-SYNC won't work with an adapter. It may work if you swap out one of them for a 970 or above with more than one DisplayPort. Keep in mind, SLI will be limited by the slowest card.
    iron man Array kkn's Avatar
    Aug 2011
    243
    6,112
    diffrent cards in sli by nvidia is not supported like amd.
    display splitter = 60hz/fps max.
    for 3 display setup you need a card whit 3 display outputs or 3 gpu's
    Cryowolf PC Specs
    OS Windows 10
    Dec 2015
    8
    for 3 1440p monitors 1 graphics card won't cut it and no way at 144hz, if you ahve 3 of those monitors and want to get the most out of it you should look at getting 2 top end cards at a min, wouldn't bother with Titan x's not worth the money, i'd get 2 980ti's but i fear that still won't be enough for 144fps on 3 1440p monitors without turning game setting down allot, then you start getting into the realms of diminishing returns on your investment, 3 way sli 980ti's....expensive and i'd say still even then i don't think you would hit 144fps on all 3 monitors at once on max settings, you'd still have to tone down the graphics a little.
  7. #7
    Feb 2015
    29
    Well, he does have G-Sync, but at $2000-2500 spent on the monitors alone, I don't see why you shouldn't spend half as much at least on the graphics power to show them off, if you can afford it.
  8. #8
    New ROGer Array
    Dec 2013
    3
    Who is the manufacture of your cards? I just looked at the specs for the 970 and it says 1 dvi-i, 1 hdmi 2.0, and 3 display ports 1.2 ???
  9. #9
    ROG Guru: Brown Belt Array davemon50 PC Specs
    davemon50 PC Specs
    Laptop (Model)Asus G752VY-DH72 (17") and Asus G752VT-DH74 (17")
    MotherboardAsus ROG LGA2011-v3 Rampage V Edition 10, x99 EATX
    ProcessorIntel Core i7-6950X Extreme 10-core 25MB Cache 3.0 GHz
    Memory (part number)Corsair Vengeance LPX Red DDR4 DRAM 64GB-4x16 3333 (CMK64GX4M4B3333C16R)
    Graphics Card #1Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Graphics Card #2Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Sound CardAsus SupremeFX Hi-Fi Audio DAC
    Monitor(2) Dell UltraSharp U2515H 25-inch monitors
    Storage #1(3) SSD's - Samsung 960 1TB M.2, Intel 535 480G, Intel 510 250G
    Storage #2(3) HDD's - Western Digital Caviar Black 2TB 3.5-in SATA III 64MB Cache
    CPU CoolerCorsair Hydro Series H80
    CaseCorsair Obsidian Series 650D Black, ATX, Mid Tower
    Power SupplyCorsair Digital AXi-Series AX1200i (1200W) 80+ Platinum Rating
    Keyboard Logitech Wireless K360
    Mouse Logitech Wireless MX Anywhere 2
    Headset HyperX Cloud II
    OS Windows 10 Pro 64-Bit
    davemon50's Avatar
    Apr 2017
    45
    1,000
    If you spent that much on monitors, they should be "chainable" through DP. At least two of them should be. Check the manual. Then use HDMI or DVDI for the third if all three are not chainable.
    Davemon50
  10. #10
    Administrator Array MasterC@ASUS's Avatar
    Aug 2014
    96
    1,492
    A splitter is only suitable for outputing the same signal to all connected monitors. For a triple-monitor surround setup with G-SYNC, you need to connect all the monitors to 3 DP ports on the same graphics card (HDMI is limited to 60Hz refresh rate and no G-Sync capability). For a massive 7680X1440 resolution using three PG278Qs, unfortunately two GTX 970s in SLI are still under-powered for what you want to do. I'd suggest two of the latest high-end graphics cards for the job. Make sure the graphics cards have 3 DP ports.
