chiribauradu wrote:
...I have a problem with my wi-fi connection. I get a slow speed ...via WI-FI, I get like 3Mbps on WI-FI ....
Hello there new ROG citizen,
Welcome to ROG's central forum !
We @Vault-Tec, wish to remind you that no matter which PipBoy (aka: your PC) version you hold,
the minute you have entered ROG country (aka: this forum), you're able to SEARCH FOR ANYTHING using your own private PipBoy (aka: your PC) ... and it's really simple:
Just look at the right upper corner of your PipBoy, then enter your query in the "Search" field, Hit enter and viola!You might ask your self - "why should I bother" ?
Well, leaving a reply in an already opened thread, with same/similar topic, can help the ROG community by having ONE THREAD that debates same subject, instead of many many others.
That way, the ROG community will have a "library of knowledge" on same topic - IN ONE PLACE.
We also, @Vault-Tec, worked really hard to concentrate the most important, most debated subjects, and PINNED SOME OF THE THREADS AT THE START OF THE 1st PAGE of this forum.Just for example, a quick search for "wifi slow" revealed the following ALREADY OPENED threads with similar topics, that you can read, learn, and debate in-them, without any need for extra Fusion cores (aka: energy):
G771jm slow wifi problem, Mediatek MT7630E connects only at 72mbps with Asus RT-AC66U Intel 7260AC terrible wireless speeds... anyone else having problems?G751 + WLAN = Heavy Lags, RubberbandingG751JY + Intel AC 7260 Issues + Replacement Card?As always, feel free to visit us at the ROG central forum ( after a search for an already similar topic thread
🐵 for any future question.
signing out,
VaultTec.
Asus G751JTSamsung EVO 850 120GB + 1TB HDD 7200RPM
Cleaned installed Win 10 HOME
My Guides:
- [POST=538713]ROG LAPTOPS: COMPLETE DRIVER LIST ![/POST]
- [POST=538713]How to install windows 8/8.1/10 on any UEFI supported laptop the PROPER way[/POST]
- [POST=538711]HOW TO (EASILY!) UPGRADE FROM WIN7 SP1/8.1 WITHOUT GOING THROUGH THE UPGRADE PROCESS ITSELF ![/POST]
- [POST=605307]HOW TO REMAP FN+KEY AND SPECIAL BUTTONS: "STEAM", "ROG" & "SHADOWPLAY"[/POST]
- [POST=539663]Win 10 x64: SETUP USB @SUPERSPEED, NO HANG-UPS! | ACCELERATES USB 3.0/2.0 TRANSFER RATE SPEED TWICE![/POST]
