Results 1 to 2 of 2
    New ROGer Array
    Jan 2016
    1
    issues with Keybot with Logitech wireless MK520 (keyboard / mouse combo)
    I was intrigued by the idea of turning on my PC from the S5 state, so I enabled this functionality in the BIOS of my Maximus Hero VIII and installed the Keybot software.
    http://rog.asus.com/383182014/maximu...-using-keybot/
    However, I'm finding that while I can indeed power on the computer with the keyboard, the mouse goes dead about 5 to 10 seconds after the desktop appears.
    Does this simply just not work with two devices on the same Logitech Unifying receiver, or is there a fix?
    edit to add:
    I've noticed that when Keybot is turned on, the Logitech Unifying software stops recognizing the Unifying receiver. As soon as I turn Keybot off, the receiver is detected again.
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,255
    Keybot works best with legacy keyboards. Running those fancy gamer keyboards or wireless keyboards can cause problems.
Tags for this Thread
