Page 1 of 2 1 2 LastLast
Results 1 to 10 of 20
    ROG Member Array otec PC Specs
    otec PC Specs
    MotherboardAsus Z170 Deluxe
    ProcessorIntel i6700K
    Memory (part number)Team Group Xtreem 2x8GB 3733Mhz
    Graphics Card #1Zotac GFX 980
    Sound CardSOUND BLASTER ZXR
    MonitorDell 5K
    CPU Coolercooler master nepton 240m
    Casecooler master HAF
    Power Supplycooler master 1000W
    Keyboard Corsair Strafe
    Mouse G602
    Headset Beyerdynamics
    Dec 2015
    What is CSM and do I need it enabled?
    Can anyone please explain what is CSM setting in BIOS and why do I need to have it enabled?
    I'm running M.2 Samsung 950 as a boot driver with Windows 10.
    Currently I don't use EFI boot partition, as I can't still figure out how to mark it as boot and rebuild bcd (when I reinstalled windows from old hard drive, I forgot to disable old EFI partition).
    Thank you!
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,247
    From Wikipedia:
    Compatibility Support Module[edit]
    The Compatibility Support Module (CSM) is a component of the UEFI firmware that provides legacy BIOS compatibility by emulating a BIOS environment, allowing legacy operating systems and some option ROMs that do not support UEFI to still be used.[48]
    CSM also provides required legacy System Management Mode (SMM) functionality, called CompatibilitySmm, as an addition to features provided by the UEFI SMM. This is optional, and highly chipset and platform specific. An example of such a legacy SMM functionality is providing USB legacy support for keyboard and mouse, by emulating their classic PS/2 counterparts.[48]
    otec PC Specs
    MonitorDell 5K
    Mouse G602
    Dec 2015
    So, if its there for compatibility reasons, how come my Windows 10 boots from a non EFI m.2 drive without any problem with CSM is disabled?
    ROG Guru: Brown Belt Array Vlada011 PC Specs
    Vlada011 PC Specs
    MotherboardRampage V E10 (BIOS 1903)
    ProcessorIntel®i7-5820K (4.5GHz 1.325V)
    Memory (part number)CMD16GX4M4A2666C15
    Graphics Card #1ASUS GTX1080Ti Poseidon
    Sound CardSound Blaster ZxR
    MonitorSamsung P2450H
    Storage #1Samsung 970 EVO PLUS 1TB
    Storage #2Samsung 850 EVO 1TB/WD Black 2TB
    CPU CoolerEK RGB Monoblock RVE10
    CaseLian Li PC-O11 WXC
    Power SupplyEVGA 1200 P2
    Keyboard Deck 87 Francium PRO - MX Brown DS PBT
    Mouse Logitech G900
    Mouse Pad Steeseries QCK
    Headset/Speakers CREATIVE T5900 5.1
    OS Windows 10 Pro x64 v1903
    Accessory #1 iPhone SE Space Grey
    Accessory #2 EK XRES D5 Revo 100 Glass PWM + CoolstreamPE 360
    Accessory #3 Noctua NF-A12x25 PWM x3 (radiator)
    Vlada011's Avatar
    Oct 2013
    21
    1,476
    And what ASUS suggest for people who use only one Windows 10 UEFI.
    To Enable or Disable CSM. Anyway settings are set to UEFI First...
    I don't want mess with Secure Boot only about CSM.
    30-35 rear 38 seconds are not bad boot time for SATA III SSD and motherboard with so many functions.
    Oct 2012
    339
    15,247
    If I recall correctly, you must disable CSM before installing Windows 10. If you installed Windows 10 with it on, then it won't let you disable it.
  7. #7
    ROG Guru: White Belt Array aceisme PC Specs
    aceisme PC Specs
    MotherboardASUS Maximus VIII Hero
    Processori7-6700K
    Memory (part number)G.Skill Trident Z F4-3200C16D-16GTZB 16GB
    Graphics Card #1EVGA GTX 980TI Classified
    Sound CardOn board sound
    MonitorASUS ROG Swift PG278Q
    Storage #1Samsung 950 Pro Series 512GB M.2 SSD
    Storage #2Intel SSD 540s - 240GB - SSDSC2CW240A3
    CPU CoolerCorsair H115i
    CaseCorsair Obsedian 450D
    Power SupplyCorsair H850i
    Keyboard Logitech G910
    Mouse Logitech G502
    OS WIN10 Enteprise
    Nov 2015
    32
    75
    A UEFI system can boot only from a GPT disk, not MBR. A BIOS system can boot only from an MBR disk and not GPT, which is why you can't take an OS disk from a BIOS system and put it in a UEFI system and expect the system to boot.
    Most UEFI motherboards come with a Compatibility Support Module (CSM), which is enabled by default. It makes the motherboard actually look like a BIOS system, allowing it to boot from NTFS and MBR disk, but you lose the UEFI features and are essentially just using BIOS. If you want to run your system as UEFI, you need to disable the CSM via the motherboard's interface before you install Windows.
    Your UEFI system can boot only from a device that has an EFI boot loader, so after the CSM has been disabled, the only boot devices that are listed will be UEFI aware.
    After Windows is installed, msinfo32 (System Information) will show the BIOS mode as UEFI, not legacy.
  8. #8
    ROG Enthusiast Array
    Jan 2013
    43
    Quote Originally Posted by aceisme View Post
    That being said if I were installing Windows 10 on a 970Evo 500GB NVMe M.2 in a ROG Maximus X Formula, would I need to change CSM to disabled and then under secure boot chnage the OS type to "other type" and clear secure boot keys?
  9. #9
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,854
    I cant speak directly from your board but on a similar buid 7700K and M9F I had to leave the CSM enabled to get it to boot from the USB. Dont remember having issues later setting to disabled. When windows wont boot on any issue like this whats worked for me is to go back a step, let windows boot, reboot to safe mode, then turn CSM off and save and exit. Then it willl boot in safe mode. restart...done
  10. #10
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,548
    I can verify changing CSM to disable after Win 10 installation
