Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
  1. #11
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    111
    4,188
    Well if your going that far, why not just change out the batteries and put some new ones in before you close up?
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
  2. #12
    New ROGer Array Internetpilot PC Specs
    Laptop (Model)Asus ROG G751JT (x5)
    MotherboardAsus Z87-A DDR3 1600 LGA 1150
    ProcessorIntel Core i7-4770 3.4 GHZ LGA 1150 8 MB Cache
    Memory (part number)Patriot 16GB Viper III DDR3 1600MHz Black Mamba Heatsink
    Graphics Card #1Gigabyte GeForce GTX 660 OC 2GB
    Storage #1Seagate 2TB BarraCuda (x2 - separate OS and data drives)
    Storage #2Seagate 2TB BarraCuda (x2 for backup)
    CaseCorsair Carbide Series Black 400R Mid Tower
    Power SupplyCorsair Enthusiast TX650 Plus Bronze
    Keyboard Microsoft Wired Keyboard 600
    Mouse Redragon M801 Mammoth 16400 DPI
    Headset Turtle Beach Ear Force Z11
    Mouse Pad Redragon P001 ARCHELON
    OS Windows 10
    Network RouterLinksys AC1750 (x5)
    Internetpilot's Avatar
    Nov 2016
    19
    3
    I now have a total of 5 (yep, five -- four working and one not) Asus ROG G751JT laptops in the family, and the first one we bought for my son started having battery problems after a little under a year. I did some troubleshooting with the help of Asus support and determined it was a problem with the charging circuit on the motherboard, so I RMA'd it to Asus under warranty (which still cost a fortune). They did fix it, but then just a few months later, a cell in the battery failed (no, the b@astards didn't replace the battery when they were in there replacing the motherboard). So I bought a 3rd-party battery on Ebay and replaced the failing one. The battery would charge up fine, but when I tried to run the laptop off the battery, it would abruptly shut down and would only stay on while plugged into AC power. Given that the battery charged up to 100% fine, I assumed it was another problem with the power circuit on the motherboard, but it was already beyond their 90-day warranty on the original warranty repair, plus I didn't want to spend another $200 shipping it back to Asus. So I just shelved it and bought another one (easily moving the hard drive over) and got the poor boy back up and running. When my other son's ROG screen cracked (closed it without realizing something was on the keyboard), I cannibalized the shelved ROG to replace that screen.
    So, I recently took our "parts" ROG off the shelf, replaced the LCD and decided to try another battery (3rd-party but from a different source), and this busted up ROG is back to running like new, runs off the battery just fine, screen looks beautiful, etc. The moral to this story is if after replacing the battery your laptop still doesn't work (at least not properly), then it could still be a battery issue and you should probably try another battery. The 3rd-party batteries have questionable reliability, but if you get one that works after swapping it out, it will most likely stay working fine. I was going to use this ROG (working battery or not) as a security camera DVR, but now that I have it working perfectly again, I'm just going to keep it around as a backup for when/if any of the other ROGs fail (it's so easy to just swap out the hard drives).
    Replacing the battery isn't that difficult. You do not have to remove the motherboard. If you have a very thin shaft phillips head screw driver, you can even remove and reinstall the two screws on the battery without removing the screen/hinges/etc. (which is great because reinstalling those wifi wires on the motherboard is a tedious pain!). Once you have the two screws out of the battery, just use a flathead screwdriver to carefully flex the bottom/back of the casing out and then use another flathead to pry the battery out. You're just looking to get the battery out over those four locking tabs. Just be careful how much force you use so you don't crack or otherwise damage the laptop casing.
    The LCD is even easier to replace than the battery. On YouTube there is a really good tutorial on the whole process for a G750 series -- don't follow that! It's very different from the G751 series laptop, and on the G751 you literally only have to remove ~8 screws (4 on the bottom edge of the screen casing and then 4 more on the inside that holds the LCD into the frame). There's one main ribbon cable and a very small ribbon cable for the camera.
    The replacement LCD was $100 and the battery was $55. That's cheaper than shipping to Asus for a warranty repair.
  3. #13
    ROG Guru: Green Belt Array haihane PC Specs
    haihane PC Specs
    MotherboardCrosshair V Formula Z
    ProcessorAMD FX 8350
    Memory (part number)Gskill F3-2400C10-8GTX
    Graphics Card #1ASUS HD 6950
    Storage #1WD Velociraptor 1TB
    Storage #2Corsair Neutron GTX 120GB SSD
    CPU CoolerCooler Master Seidon 120XL
    CaseCooler Master Silencio 650
    Power SupplyCorsair HX850
    Keyboard Corsair K70 RGB
    Mouse Logitech G500
    OS Windows 7 X64
    Network RouterLinksys E2500
    haihane's Avatar
    Jul 2013
    106
    618
    Quote Originally Posted by Internetpilot View Post
    whoa
    but where, dear sir? where did you get the parts for that price?
    no siggy, saw stuff that made me sad.
  4. #14
    OS Windows 10
    Nov 2016
    19
    3
    Quote Originally Posted by haihane View Post
    whoa
    Sorry about that -- I'm usually better about posting links. Honestly I was just way too excited to finally be approved to post here after waiting literally for 1.5 years. Not kidding.
    Anywho...
    Amazon!
    Battery:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    LCD:
  5. #15
    haihane PC Specs
    Mouse Logitech G500
    OS Windows 7 X64
    haihane's Avatar
    Jul 2013
    106
    618
    thank you! this might come in handy one day, and i'll know where to find 'em, thanks to you.
  6. #16
    ROG Junior Member Array
    Mar 2015
    3
    Hi every 1. My laptop start having the same battery problem I guess it's dead. I can turn on but it will off after few minutes. The problem now is the battery share by internetpilot from Amazon it's not sending to singapore... any 1 from singapore have idea to buy?
  7. #17
    ROG Member Array
    May 2015
    7
    Quote Originally Posted by Om3N20 View Post
    I Just ordered my replacement battery for my 751JT from AliExpress - $38 (plus the obligatory China import tax - oh well, im fed up waiting forever with a dead ROG). Will let you know when it arrives how it goes -
    https://www.aliexpress.com/item/OEM-...311.0.0.ob6V5u
    Cheers
  8. #18
    ROG Member Array
    May 2015
    7
    Exact same thing happened to my ROG 751JT 5 months ago, flying over going through airport security scanning - must have been the last straw for the battery.
    Now i turn it on while plugged in (Windows 8.1), it stays on for about 20 seconds, then shuts down again. Repeat about 10 times, then sometimes, it stays on for a few hours - its almost like it needs to get enough residual charge in there somewhere, to prevent it shutting down again, until i presume all power is removed again, and the whole shenanigans repeats again.
    Thanks Internetpilot for your info on replacing the batttery in situ - i've just ordered a replacement battery from AliExpress (im in Cyprus now) and i will try your tips on removing the battery hopefully without having to micro-disassemble the entire laptop (which some of the online videos seem to prefer)
    Will keep you posted when/if it arrives and i can get this ROG back on its feet..
  9. #19
    ROG Enthusiast Array
    Dec 2014
    41
    Same problem, if anyone hasn't bought a ROG yet - just pretend it has no battery. The battery is totally useless, if you pretend it never had one in the first place like a desktop then it will annoy you less. That is basically what I have to do now, it may as well not have a battery at all.
  10. #20
    Dec 2015
    3
    Quote Originally Posted by uprisetv View Post
    No friend, the problem is that most ROGs dont work at all without battery.
    Crazy architecture, it needs battery power too, to operate.
Tags for this Thread
