WTB RGB led strips
konfliqt
Does anyone know which companies strips we can use for our ROG motherboards that have the headers or will asus be releasing their own lighting strips eventually? So far I can only find cheap 5050 Chinese imports on amazon that mostly seem to get bad reviews on colors or likelihood to blow up 🙂 tia
Nate152
It says in the maximus viii formula manual
The RGB header supports 5050 RGB multi color LED strips 12v GRB with a maximum power rating of 2 amps and no longer than 2 meters. The RGB header is 4 pin.
As long as you don't go over 24 watts and 6 feet you should be ok.
The 39.4 inch is $44.95
https://www.superbrightleds.com/moreinfo/rgb-bars-and-strips/led-light-strips-with-multi-color-leds-...
konfliqt
I was mostly trying to find a well known PC Mod brand that could replicate all the colours the motherboard could without being an electrical risk like some you read about in their reviews. I believe I found them, arrived today and work perfectly - "Phobya LED Flexlight 120cm RGB" (exactly 2m). Their website is odd and doesn't link directly to products so i'll link where I found them in a store for anyone in the uk - https://www.scan.co.uk/products/phobya-led-flexlight-highdensity-(72x-smd-leds)-120cm-rgb
Edit - adding low quality phone clip to colour cycle without arranging/sticking them down https://www.youtube.com/watch?v=7KW4bLdAj6E
