01-27-2016 11:03 AM - last edited on 03-06-2024 02:13 AM by ROGBot
01-27-2016 11:13 AM
AKBAAR wrote:
Intel ME 11.0 Consumer PCH-H Firmware v11.0.0.1202
For 100-series Skylake-S and Skylake-H systems which come with ME firmware v11.0.x
http://www.smartredirect.de/redir/clickGate.php?u=CHoN7d6s&m=1&p=3r6MDbeCf4&t=6QdegMhg&st=&s=&splash...
http://www.win-raid.com/t596f39-Intel-Management-Engine-Drivers-Firmware-amp-System-Tools.html
or here
http://www.station-drivers.com/index.php?option=com_remository&Itemid=353&func=select&id=392〈=fr
01-27-2016 11:54 AM
Vinny1001 wrote:
Hey AKBAAR, do you know what improvements are made in that firmware version?
Also, I see the steps to install and upgrade (Section C1 on win-raid) and was wondering if you had any tips on installation/updating? Or will following those exact steps be simple enough?
Thanks for posting!
01-27-2016 01:24 PM
AKBAAR wrote:
ok here is GIF how to do flashing for your Z170 Mobo ( run as admin Command prompt)
http://i.imgur.com/r6680fr.gifv
in the end press ENTER
Be sure you are using 6700k or 6600K which is S - Skylake for Desktop
Fix - 6600k or any desktop CPU
01-27-2016 02:08 PM
Vinny1001 wrote:
Amazing GIF, perfect. That will make it a billion times more easy! I am running windows 7, so I think I have to following Section A from win-raid's website to get KMDF 1.11 then I can do the firmware upgrade. Do I need to download anything prior to running everything in the command prompt?
The F34R Channel; wrote:
I'll await the Asus UEFI update then - maybe it's already part of 1402? Does anyone know?
01-27-2016 02:17 PM
AKBAAR wrote:
You welcome man. you don't need anything. if you download the firmware from Station driver website you get all the tools included.
01-27-2016 02:34 PM
Vinny1001 wrote:
So
http://www.station-drivers.com/index.php?option=com_remository&Itemid=353&func=fileinfo&id=2035〈=fr
Just download that and follow your gif?
01-27-2016 11:58 PM
01-27-2016 12:34 PM
01-27-2016 12:47 PM
The F34R Channel wrote:
Is this something that will turn up on the Asus website as well, for the 6600K?
