Results 1 to 7 of 7
    ROG Guru: White Belt Array Jagdseelen PC Specs
    Jagdseelen PC Specs
    MotherboardASUS MAXIMUS VIII HERO
    ProcessorIntel i7-6700k @4.8ghz
    Memory (part number)G-Skill Trident Z F4-3200C14D-16GTZ
    Graphics Card #1EVGA GTX 1080 ti SC2 Gaming
    Sound CardOnboard
    MonitorASUS ROG SWIFT PG278Q and Samsung C24F390FHE 23.5"
    Storage #1Samsung 960 Pro M.2 1TB SSD
    Storage #2Seagate 3tb
    CPU CoolerCorsair Hydro Series H110i GTX
    CaseCorsair Graphite 760T Black
    Power SupplyEVGA SuperNOVA G3 750W Modular
    Keyboard Logitech G910 Orion Spectrum
    Mouse Logitech G900 Chaos Spectrum
    Headset Sennheiser G4ME ZERO
    Mouse Pad Logitech G240
    OS Windows 10 Pro x64
    Network RouterNetgear D8500 (Beta Sample)
    Accessory #1 ASUS ROG Front Base
    Accessory #2 ASUS DRW-24D3ST Black SATA DVD Burner
    Accessory #3 Oculus Rift Touch Bundle (New)
    Jagdseelen's Avatar
    Aug 2015
    11
    117
    Unhappy ROG Front Base - Detecting AIO instead of CPU temp
    When my ROG Front Base is set to CPU Temp is it shows my Corsair H110i GTX block temp instead of my i7-6700k temp.
    Corsairlink states temp is 3-5 degrees lower.
    HWMonitor states temp is 2-4 degrees lower.
    Real Temp states temp is 3-7 degrees lower.
    Is there anyway to fix this problem?
    Jagdseelen PC Specs
    Sound CardOnboard
    Jagdseelen's Avatar
    Aug 2015
    11
    117
    what no one knows anything?
    Jagdseelen PC Specs
    Sound CardOnboard
    Jagdseelen's Avatar
    Aug 2015
    11
    117
    zzzZZZzzzZZZ
    ASUS Support seem to be the equivalent to placing 100 monkeys in a room behind typewriters. Its only matter of time before one writes a novel. As for ASUS support its only a matter of time before they see your post and reply if your luck and they have a solution. If they don't have a solution they just ignore your post and hope it goes away.
    This little monkey will be sitting behind his keyboard til he gets a solution or a answer why there is no solution.
    2016 is going to be a lovely year!
    ROG Guru: Brown Belt Array Vlada011 PC Specs
    Vlada011 PC Specs
    MotherboardRampage V E10 (BIOS 1903)
    ProcessorIntel®i7-5820K (4.5GHz 1.325V)
    Memory (part number)CMD16GX4M4A2666C15
    Graphics Card #1ASUS GTX1080Ti Poseidon
    Sound CardSound Blaster ZxR
    MonitorSamsung P2450H
    Storage #1Samsung 970 EVO PLUS 1TB
    Storage #2Samsung 850 EVO 1TB/WD Black 2TB
    CPU CoolerEK RGB Monoblock RVE10
    CaseLian Li PC-O11 WXC
    Power SupplyEVGA 1200 P2
    Keyboard Deck 87 Francium PRO - MX Brown DS PBT
    Mouse Logitech G900
    Mouse Pad Steeseries QCK
    Headset/Speakers CREATIVE T5900 5.1
    OS Windows 10 Pro x64 v1903
    Accessory #1 iPhone SE Space Grey
    Accessory #2 EK XRES D5 Revo 100 Glass PWM + CoolstreamPE 360
    Accessory #3 Noctua NF-A12x25 PWM x3 (radiator)
    Vlada011's Avatar
    Oct 2013
    21
    1,476
    Madness.
    Jagdseelen PC Specs
    Sound CardOnboard
    Jagdseelen's Avatar
    Aug 2015
    11
    117
    Not madness, just angry at lack of service.
    This is my 4th problem with ASUS products in the last 12mths alone and not one has had a ASUS support assisted solution.
    Jagdseelen PC Specs
    Sound CardOnboard
    Jagdseelen's Avatar
    Aug 2015
    11
    117
    How long do I have to wait for a ASUS Rep to respond to this query?
  7. #7
    ROG Guru: Yellow Belt Array Code_Frenzy PC Specs
    MotherboardMaximus VIII Hero Alpha
    Processori7-6700k
    Memory (part number)LPX 3000MHz DDR4 (CMK16GX4M2B3000C15)
    Graphics Card #1Zotac GTX 980ti AMP!
    Storage #1(OS) Samsung SM951 256GB NVMe
    Storage #2(Data) SanDisk Ultra II 960GB SSD
    CPU CoolerXSPC Raystorm Pro with custom loop
    CasePhanteks Enthoo Luxe
    Power SupplyCorsair 1200W (Hx1200i)
    OS Windows 10 Pro
    Accessory #1 XSPC Daul bay pump/res, EX420 + RX240 rads
    Accessory #2 ROG Front Base
    Feb 2016
    12
    152
    CPU Temperatures
    I have the ROG Front Base and tend to use a program called Speccy (by Piriform) to view system data. This shows that my CPU temperature is always higher on the Front Panel than what is displayed by Speccy, and often by as much as 8 degrees which is a huge difference!
    But, in Speccy it shows the temperature of each core and the average temp. What I tend to see is that the ROG Front Panel is slow to respond, I guess it uses quite a high filter for the CPU temperature, and that it is usually reasonably close to the highest core temperature detected in Speccy. Therefore I can only assume that the Front Panel is reporting the highest core temperature and not the average of the cores?
    I can only guess at this and would appreciate it if an ASUS representative could confirm if there is any truth to my assumptions?
