01-30-2016 07:56 PM - last edited 3 weeks ago by ROGBot
01-31-2016 01:58 AM
01-31-2016 02:55 AM
01-31-2016 02:15 AM
01-31-2016 03:12 AM
Arne Saknussemm wrote:
Hi shadowraith 🙂
Sorry, bit quiet on the forum at the moment...seem to have missed your post.
Glad you got your BIOS sorted out. Now that you have done that can I suggest you clear CMOS and leave your memory at defaults for the moment.
Can you please detail part number of your memory kit?
8x8GB is a lot of memory to handle and the CPU memory controller might not be up to the task when you set XMP mode. I know many vendors sell things as plug and play but that is not the case for high frequency or large memory kits.
If you have a single kit and not two kits of same make/model maybe remove 4 sticks for now while you are setting up and installing OS....or at least leave the BIOS at F5 defaults...
I presume you have all the power connectors plugged in 24pin 8pin and 4pin atx?
With two Titan X I would also plug in the EZplug molex connector at the bottom of the board
01-31-2016 03:46 AM
shadowwraith wrote:
No worries, I am actually kind of proud of myself for being able to do what I have already done.
01-31-2016 04:15 AM
01-31-2016 04:22 AM
01-31-2016 04:36 AM
There is a clear CMOS button on the I/O panel (back of the computer)
If you have problems....switch off power and press this button once lights on board have gone out...it resets BIOS to defaults.
Many times the auto overclocking in the BIOS results in some stability problems and/or overvolting of components....
01-31-2016 04:46 AM
