Results 1 to 9 of 9
    ROG Enthusiast Array
    Jan 2016
    25
    Z906+Phobeus analog vs optical
    Hello guys im enjoying my Phobeus card with Z906 Logitech speakers while im watching movies and playing games
    right now im using analog connection alongside with Dolby theater and i like the sound
    however i was wondering if it would be the best to use optical with this soundcard?
    so optical or analog with those speakers?
    ROG Guru: Orange Belt Array
    Oct 2012
    12
    272
    Keep the analog output, with optical you'd need ddl live in order to get surround sound ans for some obscure (and frankly crappy) reason asus removed that functionnality....
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,548
    skours, I am using the same speaker system, i have 2 computers connected to it, one analog and the other optical obviously, both ASUS on board sound, as Glasofruix says I don't get surround through the optical connection but still very good sound form either
    Jan 2016
    25
    Quote Originally Posted by Menthol View Post
    thanks guys i will stick with analog (i thought that if you connect optical and enable dolby theater v4 you get surround)
    by the way did you encounter any problems with the z906 so far?
    i have seen a lot of people saying that their units totally fail after 6 months or 1 year...
    Menthol PC Specs
    MonitorBENQ 32" 4K
    Keyboard Corsair
    Mouse ASUS Strix
    Mouse Pad ASUS
    OS 10 X64 Pro
    Menthol's Avatar
    Jan 2012
    241
    4,548
    I have had mine for several years, one move, sounds great, multiple input sources, wireless remote, what's not to love
    Jan 2016
    25
    thanks mate for the reply
    one question more do you get any heat on the back on the sub on the plate after sometime during play?
  7. #7
    ROG Member Array
    Oct 2015
    17
    Can't you use DTS Connect for 5.1 over optical? I'm pretty sure that's what I did with my Phoebus. I seem to remember that some games required the Virtual 7.1 Speaker Shifter to bring the center channel back.
    The plate on the back of the sub is a heatsink, designed to wick away heat from the amplifiers. Having it heat up is very normal ☺
  8. #8
    Jan 2016
    25
    Quote Originally Posted by juzz86 View Post
    thanks man and no i didnt try DTS with optical i will give a go though and report back maybe this weekend
    however i try with Dolby home theater and it was a mess
    the volume didnt respond at all and the speakers didnt play correct some was weaker than others
    maybe it was something that i did wrong....?(also set the spidf as default devise)
  9. #9
    ROG Member Array
    Oct 2015
    17
    Yeah I tend to steer clear of Dolby, only because it seems to be a poorer encoder for up scaling compared to DTS. For me personally, DTS Connect over optical has been plug and play for every sound card on all my Logitech speakers. It's worth a shot mate, just don't forget the virtual 7.1 thing for the center channel. Let us know how you go ☺
