BIOS and Other problems
Blackkatt
Hi ASUS!
Here are some issue I would like you to correct.
Reports found in Event Viewer
1. Event ID: 15 - MAXIMUS VIII HERO/BIOS Version 1402
The embedded controller (EC) returned data when none was requested. The BIOS might be trying to access the EC without synchronizing with the operating system. This data will be ignored. No further action is necessary; however, you should check with your computer manufacturer for an upgraded BIOS.
2. Event ID: 414 - Part of ASUS AI Suite 3 V1.01.30?
Task Scheduler service found a misconfiguration in the NT TASK\SS2Svc64Run definition. Additional Data: Error Value: C:\Program Files\ASUSTeKcomputer.Inc\SS2\UserInterface\x64\SS2Svc64.exe.
3. Event ID: 219 - AiChargerPlus/ASUS AI Suite 3 V1.01.30
The driver \Driver\AiChargerPlus failed to load for the device PCI\VEN_8086&DEV_A12F&SUBSYS_86941043&REV_31\3&11583659&0&A0.
I should add that sometimes Windows won't boot after a restart. Just hang at the boot logo. If this is true after ASUS AI Suite 3 V1.01.30 I have to confirm. The boot logo is also shown for 10 seconds even if set to "0"
Finally, more then two years (01-04-2014) ago I asked/had a conversion with Raja to change my username. Nothing has happen sense :rolleyes:
0 REPLIES 0
