Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    ROG Member Array rodval PC Specs
    rodval PC Specs
    MotherboardRAMPAGE VI EXTREME @ 2002 MODDED BIOS (MCU49)
    Processori9 7900x @ 4.7GHz
    Memory (part number)1 x GSKILL64GB3600C15 @ 3600MHz (8x8GB)
    Graphics Card #1Gigabyte GTX 1080 Ti AORUS Xtreme 11GB
    Graphics Card #2Gigabyte GTX 1080 Ti AORUS Xtreme 11GB
    Sound CardCreative Soundblaster Audigy Rx
    Monitor3 x LG 27EA83-D 10bit @ 8040 x 1440
    Storage #12 x INTEL 750 AIC 1.2TB VROC (RAID0 2.4TB)
    Storage #22 x Crucial M550 960GB RAID0 PCH + 2 x SAMSUNG SM970 EVO 2TB RAID0 (WIN)
    CPU CoolerEKWB CPU + Chipset + 2 x GPU + 2 x INTEL 750 AIC
    CaseCoolermaster StormTrooper
    Power SupplyCorsair AX1500i
    Keyboard Microsoft Sculpt Comfort
    Mouse Microsoft Sculpt Comfort
    Headset/Speakers Creative 7.1 Inspire
    OS Windows 10 1909 build 18363.418
    Network RouterLinksys WRT 1900ACS
    Accessory #1 Lamptron CM615
    Accessory #2 ROG Front Panel
    Dec 2013
    8
    Help on fine tune overclocking voltages
    Hello all,
    After reading a lot from this forum I managed to get a very good overclock on my system, but with some high voltages and surely I know I can get lower voltages and maintain the stability.
    Let's get to my bios settings, using 1902 modded:
    CPU i7-5930K @ 4.5GHz
    Uncore @ 4.0GHz
    DDR4 @ 3000MHz, Total of 64 GB
    CPU Strap 125MHz
    VCC Core 1,4218
    VCC Uncore 1,25
    VCC SA 1,3812 (I know... too high!!!!!)
    CPU SVID Disabled
    CPU Input 1,92
    DRAM SVID Disabled
    DRAM Voltage 1,415
    PCH Core Voltage Auto
    PCH I/O Voltage 1,5125
    VCCIO CPU 1,25
    VCCIO PCH 1,25
    VTTDDR 0,71875
    PLL Voltage Auto
    PLL Offset Mode +
    PLL Reference offset Auto
    Spread Spectrum Disabled
    Primary Timmings on RAM manual mode at 15-17-17-35-2T
    DRAM Eventual Voltage 1,415
    Enhanced Training Diasabled
    Swizzling Bit 0/1/2 Disabled
    I know that I'm giving too much juice to some components and want some advice on where to start to decrease some of theses high voltages.
    Temps on AIDA Stress test get around 82C.
    Thanks all
    ROG Guru: Green Belt Array drop4205 PC Specs
    drop4205 PC Specs
    Laptop (Model)What are laptops
    MotherboardMaximus XI Formula
    ProcessorI9-9900K
    Memory (part number)Gskill Trident Z F4-3200C14-32GYZR
    Graphics Card #1Nvidia Reference RTX2080TI
    Graphics Card #2ha I wish
    Graphics Card #3ha I wish
    Graphics Card #4ha I wish
    Sound Cardha I wish
    MonitorMSI Oculux-NXG251R
    Storage #1Samsung970 EVO Plus 1T
    CPU CoolerHeatkiller
    CasePhantex Evolove X
    Power SupplySessonic Prime Titanium 850
    Keyboard ROG Strix Flare
    Mouse ROG Gladius II
    Headset Astro A40
    Mouse Pad Corsair
    Headset/Speakers Astro A40TR
    OS Windows 10 Home 64 Bit
    Accessory #1 Ek GPU Block
    Accessory #2 EK SE 360 Rad, EK PE 360 Rad
    Accessory #3 EK D5 Vario 140 Pump/Res
    drop4205's Avatar
    Mar 2013
    47
    549
    4.5 should be down round 1.25 to 1.3 vcc
    Maximus XI Formula, I9-9900k, Phantex Evolove X, Seasonic Titanium 850W, Custom loop PE360+SE360 Rad, G.Skill Trident Z F4-3200C14 32g, Nvidia Reference RTX 2080 TI, Samsung 970 EVO Plus 1Tb, ROG Strix Flare keyboard, ROG Gladius II
    ROG Guru: Green Belt Array Qwinn PC Specs
    Qwinn PC Specs
    MotherboardRampage V Extreme - BIOS 3301
    Processor5930K @ 4.4 GHz Adaptive 1.27v / 4.2 Ghz cache Offset +0.27v / Input 1.92v / LLC7
    Memory (part number)G.Skill 32gb DDR4-2666Mhz 15-15-15-35-CR2 1.2v at XMP settings
    Graphics Card #1Gigabyte Gaming G1 980Ti OC to 1455Mhz Core 8000Mhz memory at Stock Voltage
    Graphics Card #2Gigabyte Gaming G1 980Ti SLI
    MonitorROG Swift PG278Q
    Storage #1Intel 750 PCIe 1.2TB
    Storage #2Sandisk Ultra II 960GB SSD
    CPU CoolerThermaltake Water 3.0 Ultimate (360" rad AIO)
    CaseThermalTake v71 Full Tower
    Power SupplyEVGA SuperNOVA 1200 P2
    Keyboard Saitek Eclipse II
    Mouse Razer A5090 Master of Destiny
    OS Windows 10 Professional 64 bit Build 10586
    Jul 2015
    46
    670
    Yes, SA *way* too high. Way way way WAY way way too high. More than 1.05v isn't going to help much of anything, and if it does, it's too expensive.
    1.42v vcore is a bit more than I'd go for even just benchmarking, way too high for 24/7. drop4205 is correct, go for 1.25v to 1.3v.
    Uncore at 1.25v is probably more than you need for 4.0, and no amount of cache OC is really worth going over 1.2v. I get 3.8Ghz with manual 1.1v. You will probably help your memory stability with up to 1.2v though... have you had issues getting 64gb to play nice?
    Input voltage at 1.92 is fine. Is that with LLC on auto?
    The various IO voltages I know nothing about, I leave them on auto, and unless you REALLY know what you're doing, you should too.
    Aida temp of 82c is way too high. That's the max you'd want to hit with OCCT or Prime. Do NOT run OCCT or Prime until you've got those voltages into sane ranges. Aida temps should be around 65c at most. Fixing the voltages as drop and I've suggested above should get your temps to safe levels.
    ROG Guru: Yellow Belt Array
    Sep 2015
    11
    246
    I agree with qwinn, 82 is to high for aida stress test, if those voltages are the only way to pass aida then consider less OC -
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    499
    13,571
    Hi rodval
    Couple of questions...where you say total 64GB is that more than one kit of RAM?
    EDIT:OK so I see in PC specs that is two 32GB kits.
    That might be why you have to apply so much voltage to get things running...certainly wont help your IMC...
    Unless you are in a very niche usage case you won't need all that RAM...maybe split out one kit and see how you go with one 32GB kit...easy to do by looking at serial numbers on sticks.
    I would agree with the other voices in the thread...temps and volts are a bit too high high for my liking ....for benchmarking run OK but for 24/7 OC seem like a lot. 1.3v or as near as damn it for 24/7 OC seems more sensible. Cache OC not worth the volts 24/7.
    rodval PC Specs
    Dec 2013
    8
    Thanks guys....
    So I went back a few steps and decided to lower some of these OC.
    Got core@4.4GHz stable with Adaptive Offset 0.02v and Adaptive Reference 1.26v. Uncore@3.8GHz with 1.1v fixed manual.
    RAM @2666 with 1.25v and SA 1.05v. CPU Strap lowered to 100MHz. Remaining tunnings as were in my first post.
    AIDA Stress test got 63.7C
    P.S.: LLC is set to auto.
    P.S.2: It´s a 2 x 32GB kit. Will increase RAM now and see what I got.
  7. #7
    Qwinn PC Specs
    Jul 2015
    46
    670
    Well, I can't argue with any of that, seeing as other than SA (mine is set to Auto), that is my 24/7 OC settings exactly, heh. I'm doing only 32gb tho. Nice work.
    In fact, very very nice work if you got that fully working with mixed 32gb kits.
    Give OCCT a few hours run to prove overall stability. Five to ten consecutive Realbench benchmarks is good for testing adaptive OCs. Aida alone won't really test your stability much.
    Did you put all your other voltages (besides vcore, cache, input and SA) back to auto?
  8. #8
    rodval PC Specs
    Dec 2013
    8
    Hello Qwinn
    Yes, it's 2 mixeds 32GB kit.
    Now I'm working to get DRAM @2800 stable. Had to increase core to 0.02/1.28v and SA to 1.12. Uncore still fixed @ 1.1v.
    DRAM @ 1.37 (spec is 1.35) and Switching Freq @ 300KHz.
    All the remaining turnings are exactly the same on my first post.
    Will try some fine tuning on PCH I/O to be able to bring down SA and jump to 2933MHz step.
    Running AIDA for 2 hours, listening some good music and surfing on net. Everything appears to be fine.
    After reaching top DRAM freq will start some hard test (Realbench and OCCT).
  9. #9
    Qwinn PC Specs
    Jul 2015
    46
    670
    I don't think 133 or even 300 Mhz memory oc is worth that extra voltage at all. On Haswell-E, even 5x that much memory OC has almost no impact at all on performance outside of some benchmarks and very niche video editing applications. If you got mixed kits working at 2666 at 64gb, you're very lucky and doing great, I would recommend not getting greedy for a tiny additional OC that really won't improve your performance at all.
    Certainly, before going beyond 2666, you need to confirm that the mixed kits are truly stable with 12 sessions of HCI Memtest running at least 8 hours. If you can boot Linux you can use GSAT to stress memory as well.
    Besides, until you run OCCT, you don't even know how much voltage headroom you're going to require to get truly stable. It may be more than you expect. I recommend taking the 4.4, 3.8, 2666 and sticking to it until it's fully stable. I suspect you won't have any temperature headroom left by the time you've done that. I have one of the best AIO liquid coolers on the market (360mm radiator) and those same settings get me to 81c in occt.
  10. #10
    Sep 2015
    11
    246
    Id like to know what music you are listening , right now im looking for some titles to listen to Any suggestions are welcome as long as they are your personal choices,
