I have just bought a GL752VW and i have several issues that kind of drive me nuts so if anybody has any input for any of them, thank you very much.
A) First of all the colors seem quite intense and dark ... i had an old Assus with very nice colors so i am not at all pleased by this one from this POV. I tried several programs to adjust colors and brightness/contrast and in the end i managed to get to some status that i can live with but is far from what i wanted. Issue is that the color range is very dark so in order to see the color i have to bring the brightness up, but if i do that all becomes very intense on the screen and i get dizzy ... The best i found to calibrate the colors was pstrip and
http://www.phototopics.net/pt_gamma/.
Anybody has the same issues with GL752 or found better programs to calibrate colors/contrast ?
B) The Intel is keeping my frequency to 60Hz. Yes i know there are a lot of guys that say 60 is enough, pls do not reply if you are one of them, i am not interested in a thread discussion on this topic.
I tried the CRU but still cannot see the custom refresh rates that i define with them. Have no clue why ... Any idea ? I tried even in 1600x900 but is not working regardless what frequency are you in.
C) Many games do not work anymore for various reasons. This is actually the biggest pain.
C1) Unreal 2004 - it is getting installed but after that when i try to start it says it cannot find the cd. I have the image and is mounted (do not have the original CD cause i copied it on the HDD so not sure if with original cd could work - still searching for the original
🙂 ) - Any idea why this can happen ?
C2) Brood is getting installed but when to start it crashes with some memory fault. That if i let it run as "Windows 7". If i chose windows 98 then i get same issue as in C1 - no CD found. The CD is original.
C3) DOS Box does not work at all. It installs, starts, but i do not get a prompt ... so i cannot do anything with it.
Actually the only game that still works from what i had (no new stuff tried) only Panzer III worked and that with a big patch patch in the left upper part of the screen
I am trying now to reinstall Windows as 32 bit, hoping the issues from (C) come from the x64 versions, but i do not have high hopes. If anybody has any idea of what i can try or encountered the same or other issues, pls reply
Thanks,
Adrian
