Results 1 to 4 of 4
    New ROGer Array
    Feb 2016
    2
    Thermaltake riing rgb fans connected to the motherboard are not remembering settings
    I have a set of Thermaltake riing rgb fans, complete with a controller unit that allows you to change the LED colour, and also the LED mode (constant colour, cycle colours, off). Basically the controller unit has 2 fans plugged into it, and then the controller unit itself is plugged into one of the chassis fan headers on the MB. The controller unit is supposed to remember the setting after a reboot, but it doesn't in my system. I thought it may have been a faulty controller, but I have tried 2 different controllers, and they behave the same. So that has me thinking that maybe the MB is causing it, perhaps by not supplying enough voltage to the controller? Do the chassis fan headers on the Gene support multiple fans from one fan header?
    ROG Guru: Green Belt Array drop4205 PC Specs
    drop4205 PC Specs
    Laptop (Model)What are laptops
    MotherboardMaximus XI Formula
    ProcessorI9-9900K
    Memory (part number)Gskill Trident Z F4-3200C14-32GYZR
    Graphics Card #1Nvidia Reference RTX2080TI
    Graphics Card #2ha I wish
    Graphics Card #3ha I wish
    Graphics Card #4ha I wish
    Sound Cardha I wish
    MonitorMSI Oculux-NXG251R
    Storage #1Samsung970 EVO Plus 1T
    CPU CoolerHeatkiller
    CasePhantex Evolove X
    Power SupplySessonic Prime Titanium 850
    Keyboard ROG Strix Flare
    Mouse ROG Gladius II
    Headset Astro A40
    Mouse Pad Corsair
    Headset/Speakers Astro A40TR
    OS Windows 10 Home 64 Bit
    Accessory #1 Ek GPU Block
    Accessory #2 EK SE 360 Rad, EK PE 360 Rad
    Accessory #3 EK D5 Vario 140 Pump/Res
    drop4205's Avatar
    Mar 2013
    47
    555
    shouldnt power connector to psu be ok for power to fans and the connector to the motherboard control the fans? Just wondering myself as I thought bout getting these
    Maximus XI Formula, I9-9900k, Phantex Evolove X, Seasonic Titanium 850W, Custom loop PE360+SE360 Rad, G.Skill Trident Z F4-3200C14 32g, Nvidia Reference RTX 2080 TI, Samsung 970 EVO Plus 1Tb, ROG Strix Flare keyboard, ROG Gladius II
    New ROGer Array
    Feb 2016
    2
    Thanks for the replies. I ended up buying a molex to fan connector adapter, and am just going to go straight from PSU to fan controller. Should arrive tomorrow, so I'll let you know how I get on.
Tags for this Thread
