Results 1 to 8 of 8
    New ROGer Array MXF5700 PC Specs
    MXF5700 PC Specs
    MotherboardASUS ROG Strix Z370-I Gaming
    ProcessorIntel® Core™ i7-8700K
    Memory (part number)Corsair Vengenance LPX 3200 (16GB)
    Graphics Card #1ASUS Geforce GTX 1080 TI Turbo 11GB
    Sound CardIntegrated 8-channel
    MonitorDell Laser Projector S718QL
    Storage #1Samsung PRO 960 512GB NVMe
    CPU CoolerAsetek 545LC
    CaseDan Cases A4-SFXv2
    Power SupplyCorsair SF600
    Keyboard Logitech G613
    Mouse Logitech G603
    Headset Razer Tiamat 7.1v2
    OS Windows 10 64-bit
    Feb 2016
    3
    Rampage V Extreme BIOS 1902 Overclocking Presets Help
    I'm new to overclocking and wanted some expertise from the community.
    I searched the forums but didn't find a thread that answered my question so I might be posting this in the wrong section.
    Anyways, I recently put together my PC and have been breaking it in before I overclocked anything. My PC specs are in my profile.
    The overclocking presets have made it easy but I can't seem to use both the 8-core preset and the XMP profile for my memory, I can only do one or the other.
    Here are the changes from defaults:
    CPU
    1. Ai Overclock Tuner [Auto]->[Manual]
    2. CPU Core Ratio [Sync All Cores]->[Pre Core]
    3. 1-Core Ratio Limit [Auto]->[44]
    4. 2-Core Ratio Limit [Auto]->[44]
    5. 3-Core Ratio Limit [Auto]->[44]
    6. 4-Core Ratio Limit [Auto]->[44]
    7. 5-Core Ratio Limit [Auto]->[43]
    8. 6-Core Ratio Limit [Auto]->[43]
    9. 7-Core Ratio Limit [Auto]->[43]
    10. 8-Core Ratio Limit [Auto]->[42]
    11. Min. CPU Cache Ratio [Auto]->[30]
    12. Max. CPU Cache Ratio [Auto]->[30]
    13. Fully Manual Mode [Enabled]->[Disabled]
    14. CPU Core Voltage [Auto]->[Manual Mode]
    15. CPU Core Voltage Override [Auto]->[1.350]
    16. CPU Cache Voltage [Auto]->[Manual Mode]
    17. CPU Cache Voltage Override [Auto]->[1.250]
    18. CPU Load-line Calibration [Auto]->[Level 9]
    19. CPU VRM Switching Frequency [Auto]->[Manual]
    20. CPU Power Phase Control [Auto]->[Extreme]
    21. CPU Power Duty Control [T.Probe]->[Extreme]
    22. CPU Current Capability [Auto]->[140%]
    Memory
    1. Ai Overclock Tuner [Auto]->[XMP]
    2. CPU Strap [Auto]->[125MHz]
    3. BCLK Frequency [100.0]->[125.0]
    4. 1-Core Ratio Limit [Auto]->[28]
    5. 2-Core Ratio Limit [Auto]->[28]
    6. 3-Core Ratio Limit [Auto]->[28]
    7. 4-Core Ratio Limit [Auto]->[28]
    8. 5-Core Ratio Limit [Auto]->[28]
    9. 6-Core Ratio Limit [Auto]->[28]
    10. 7-Core Ratio Limit [Auto]->[28]
    11. 8-Core Ratio Limit [Auto]->[28]
    12. Min. CPU Cache Ratio [Auto]->[24]
    13. Max. CPU Cache Ratio [Auto]->[24]
    14. DRAM Frequency [Auto]->[DDR4-3000MHz]
    15. Turbo Mode [Enabled]->[Disabled]
    16. Turbo Mode [Enabled]->[Disabled]
    I've tried to combine these two to the best of my ability but it fails.
    Can someone help me figure out whether this is even doable and/or if there may be a better way to achieve both.
    Thank you
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,255
    What you can do is enable XMP and change the Core Ratios to 36 which will give you a 4.5GHz overclock. Then set the Vcore to 1.35V as you did and test for stability.
    ROG Enthusiast Array kaaala PC Specs
    kaaala PC Specs
    Laptop (Model)rMBP mid 2014
    MotherboardAsus Rampage V Edition 10
    ProcessorE5-2679 V4
    Memory (part number)Corsair Dominator 4X16G 3000MHz
    Graphics Card #1GTX 1080 FE
    MonitorDell U2312HM
    Storage #1Samsung 950 PRO 256G
    Storage #2Samsung 850 EVO 1T
    CPU CoolerEK customer loop(360+240+D5)
    CaseCoolermaster Mastercase Maker 5
    Power SupplyCorsair AX1200i
    Keyboard Filco Najestouch 2
    Mouse Logitech G502
    Mouse Pad Logitech G440
    OS Windows 10 pro
    Accessory #1 Wacom CTL-470
    Nov 2015
    44
    In my case, I used XMP files
    memory @ 3000
    B Frequncy @ 125
    CPU @ 36
    Cache @ 32
    CPU Volt @ 1.3
    The worst temp single core is 84c.
    MXF5700 PC Specs
    Mouse Logitech G603
    Feb 2016
    3
    It seems to have taken your suggestion about modifying the XMP profile so I will confirm stability over the next couple of days.
    I left the min/max cache value @ 24. Would there be a benefit/consequence to setting it up to 32?
    Thank you for the help.
    kaaala PC Specs
    ProcessorE5-2679 V4
    MonitorDell U2312HM
    Mouse Logitech G502
    OS Windows 10 pro
    Nov 2015
    44
    Higher cache = Higher memory r/w performance
    Best setting would be the same ratios of CPU and cache like CPU and cache both @ 36
    But in that case, u will need a really good cooling solution for ur CPU
    Oct 2012
    339
    15,255
    Quote Originally Posted by MXF5700 View Post
    What I would do is leave Cache overclocking as the last thing on the list. Overclocking the Core is where the true performance is at.
  7. #7
    ROG Member Array
    Aug 2015
    14
    I've noticed XMP doesn't seem to do anything other than change your multiplier. I was hoping it would load all the DRAM values (CAS/RAS/etc.) and I could override my own o/c but it seems useless. I just leave it to manual.
  8. #8
    MXF5700 PC Specs
    Mouse Logitech G603
    Feb 2016
    3
    Quote Originally Posted by Boofster View Post
    Yes, the timings are definitely not in the change list above but isn't the XMP profile specifically for the low latency RAM?
    The new timings are in the profile name... why would it not change those? Mine should be set to 14-16-16-35; 1.35V.
    I haven't had to do this manually before, what exactly should I change to get my RAM up to par if the profile isn't actually doing it?
Tags for this Thread
