Been trying to get a stable o/c for a few days now. After several aborted AIS3 attempts I followed some vids and cranked the synced cores to 100.0x46 and turned on XMP for my 2666MHz RAM.
I wasn't at all unhappy with a ROGBench of 98k but it looks like several others with 6600K + GTX970 combos pushed that a little more. So fans to max, give the Strix a wee push and I set off for a 3 run attempt.
Run 1 was about 96k, but runs 2 & 3 hit 23k+ and that is where I think I need to stop fiddling.
I see several others exceed this by a margin but honestly is it worth it (other than for kudos)? Also The CPU core voltage now sitting on auto hovers around 1.456V - whilst I know not if this is good or bad it does seem a fair bit higher than the 1.35V AIS3 was setting it to.
Thoughts on that?
