Gl551JW: Power Limit Throttling and random BSOD problems.
nickwarrior5
I was getting random BSOD of whea_uncorrectable_error. In XTU, I found out that my cpu was being power limit throttled! I tried to test if it was my power supply by unplugging that, I also tried to test if it was my battery by taking out the battery and having power straight from the PSU. I even tried a factory reset and to still no avail. Does anybody know how to fix my problem? I dont want to have to send in my laptop.
28 REPLIES 28
warryabel
uninstall xtu and see what you get! before uninstall get back to default profil in xtu.
Well, when I uninstall xtu, same problem. Also same problem if it is default profile.
this issue can be so many things...maybe harddisk, make sfc /scannow and chkdsk /f in cmd
sometimes bad ram or,or,or
warryabel
intel management engine installed?
Yes
warryabel
on latest bios?
warryabel wrote:
on latest bios?
Yes. I also ran those things in cmd and no errors.
Clintlgm
Level 14
What are your temps running? CPU and GPU will throttle to protect themselves
G752VY-DH72 Win 10 Pro
512 GB M.2 Samsung 960 Pro
980m GTX 4 GB
32GB DDR 4 Standard RAM
Z97 PRO WiFi I7 4790K
Windows 10 Pro
Z97 -A
Windows 10 Pro
My gpu temps are around 70c while gaming. When stress testing my cpu it is around 85c. I do notice though that my package TDP is higher than normal. Could more dust = higher temps = power limit throttle?
