Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    ROG Member Array
    Aug 2015
    12
    GL551JW Random Restarts, no BSOD, Kernel-Power Error 41
    Hi, I've had an Asus GL551JW Gaming laptop since for the last six month and so far about twice a month it will crash with this error:
    Log Name: System
    Source: Microsoft-Windows-Kernel-Power
    Date: 2/17/2016 3:54:37 PM
    Event ID: 41
    Task Category: (63)
    Level: Critical
    Keywords: (35184372088832),(2)
    User: SYSTEM
    Computer:
    Description:
    The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
    Event Xml:
    <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
    <System>
    <Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
    <EventID>41</EventID>
    <Version>3</Version>
    <Level>1</Level>
    <Task>63</Task>
    <Opcode>0</Opcode>
    <Keywords>0x8000200000000002</Keywords>
    <TimeCreated SystemTime="2016-02-17T23:54:37.170475100Z" />
    <EventRecordID>37995</EventRecordID>
    <Correlation />
    <Execution ProcessID="4" ThreadID="8" />
    <Channel>System</Channel>
    <Computer> </Computer>
    <Security UserID=" " />
    </System>
    <EventData>
    <Data Name="BugcheckCode">0</Data>
    <Data Name="BugcheckParameter1">0x0</Data>
    <Data Name="BugcheckParameter2">0x0</Data>
    <Data Name="BugcheckParameter3">0x0</Data>
    <Data Name="BugcheckParameter4">0x0</Data>
    <Data Name="SleepInProgress">0</Data>
    <Data Name="PowerButtonTimestamp">0</Data>
    <Data Name="BootAppStatus">0</Data>
    </EventData>
    </Event>
    Has anyone figured out a fix for this forced restarting or should I contact customer support and get this repaired?
    ROG Guru: Blue Belt Array Gps3dx PC Specs
    Gps3dx PC Specs
    Laptop (Model)Current: G751JT | Retired: G55VW, G51JX
    MotherboardInc M.2 slot
    Storage #1Samsungs EVO 850 128GB
    Storage #21TB HGST Travelstar 7K1000 (HTS721010A9E630)
    CPU CoolerMother Nature & Thermodynamics laws
    Mouse Logitech MX 518
    Headset/Speakers Logitech T6060
    OS Cleaned installed Windows 10 HOME x64
    Accessory #1 Leap Motion
    Feb 2015
    71
    785
    Run THIS.
    what drivers are shown in red ?
    what is the "bug check string" and "bug check code" ?
    ( show us screenshot of these two tabs enlarged )
    what do you run when it happens ? what is working during that time ?
    what OS you have ?
    which driver do you use ?
    if you got weird BSOD twice a MONTH - it's not something that should really bother, in compression to BSOD or crashes that happens every few hours.
    ROG Guru: White Belt Array maf23's Avatar
    Jan 2016
    94
    Are you sure it is not due to battery running dead while in sleep mode?
    ROG Member Array
    Aug 2015
    12
    I have other events that may provide more information
    ROG Member Array
    Aug 2015
    12
    Quote Originally Posted by maf23 View Post
    Yeah, it's almost always plugged in
    Jan 2016
    94
    Have you added/changed memory? Is CPU being tasked when it happens?
  7. #7
    ROG Member Array
    Aug 2015
    12
    Logs with information
    Here's another crash from about a month back
  8. #8
    ROG Member Array
    Aug 2015
    12
    I have not made any changes to what is stock with the Asus GL551-DS74
    I had 2 tabs open in google chrome, I had a word document being edited and a calculator app open at this time so it's doubtful it was my CPU being tasked, I can't find an error saying my CPU was limited by firmware or anything like that. Is there anywhere I can check for that?
  9. #9
    Jan 2016
    94
    Sounds like faulty RAM to me. You could try re-seating it. You can launch task manager to monitor CPU. Unless you are overheating this should not be the culprit. I would run Memtest or try removing your memory modules selectively (if you have more than one).
  10. #10
    ROG Member Array
    Aug 2015
    12
    I'll run memtest and post the results
Tags for this Thread
