Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
    New ROGer Array
    Jan 2016
    1
    G752, System and Compressed Memory task constantly at 18%
    My System is always running at 20% even when idle.
    System and compressed memory task is stuck at 18%.
    Does anyone know how to resolve this?
    Opening details on it doesn't provide any more info. It shows it's "System and compressed memory".
    I don't know if it has always been this way or it's a result of installing software. I'd love to get that % down.
    Any ideas? I read someone else with a Fujitsu saying it was due to a bad driver on their SSD and when they installed a different one it solve their issues. Not sure it's related.
    Thanks!
    S
    ROG Enthusiast Array
    Aug 2015
    48
    install hitmanpro alert 3.1.1 and do make a scan I solved so
    ROG Enthusiast Array pigulici's Avatar
    Jan 2016
    69
    Same problem here, 16-20% cpu all the time, on asus rog g752vy, all drivers from asus website and fresh win10 install(2 week old)...
    Jan 2016
    69
    I managed to stop that behaviour, go to task manager : control panel > task scheduler > microsof>windows>memory>RunFullMemoryDiagnostic disabled
    ROG Member Array
    Dec 2014
    8
    System and compressed memory (high cpu load in idle mode 20%)
    Thank you. But this has not solved the problem for me.
    ROG Guru: White Belt Array
    Feb 2016
    18
    118
    That has happened to me as well. The one thing I found that ended up actually helping me (On the G752VT) was switching the BIOS version I was using.
    I followed every guide I could online, and none of them mentioned this. But it is what ended up helping me.
  7. #7
    ROG Member Array
    Dec 2014
    8
    Ok, thank you for your answer. I have read that to. But I need the 2013 bios because I want to have the option for AHCI in stead of Raid. The older ones do not have that option. I also tried every possibly solution on the forums.
    Anybody?
    Quote Originally Posted by Ancients View Post
  8. #8
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,855
    Go here and get the latest IRST drivers. 14.10.0.1016 is out. Bet your OS is still on 14.6 or older and your bios is on 14.8. You need to have either both matched or the OS newer. This happens 100% of the time on the so called "Clean installs" of windows. Id like to know if anyone has actually done a "clean install" wothout "dirtying up" their machine? My performance benchmark challenge still stands. My factory image with a 5 minute minimal bloatware uninstall and regular updates against your "Clean Install". Guarantee either the performance difference is negligible or you lose.
    http://www.win-raid.com/t2f23-Intel-...QL-v-WHQL.html
  9. #9
    ROG Member Array
    Dec 2014
    8
    Thanks, but no luck. Now I use: 14.10.0.1016 as you said......problem is still there. I have used a clean install. Setup from the windows 10 dvd. latests Asus Drivers from their website, all windows updates, and now with you're advise Intel Rapid Storage 14.10.0.1016 driver. The problem still there. I use Bios 213 on My G752VY ROG laptop. The cpu is on 19 % load all the time.
    Help..Thanks guys.
  10. #10
    Jan 2015
    107
    I once read about a guy who got it fixed by updating the Wi-Fi driver, give it a try, try to find the latest one on the Intel website.
    Laptop: G751JL
    Processor: i7-4750HQ
    Graphics Card: GTX 965M
    Memory: 8 GB Samsung (stock)
    Storage #1: Samsung 850 EVO 250gb
    Storage #2: 1 TB 7200 rpm (stock)
    OS: Windows 10 x64
