2 SATA Not working 3 USBs not working (2x usb3.0 1 USB2.0)
ayman_abm
Dears,
I have Rampage V Extreme /U3.1
I found 2 issues:
  • 2x USBs beside the Ethernet not working and the top one beside (ROG Connect) USB2.0 also not working
  • Last 2 SATA Ports also not working (the 2 SATA ports beside SATA Express)
what do you think guys about this!?
also how to build a RAID 0 from 2x m.2 950Pro. even the m.2 connected i cant see its drive in the raid list of drives. (ps: i have also a PCIe card that convert the m.2 to PCIe .. will this help?)
Minsekt
since bios 1902 the usb port next to the rog connect port does not work for me either. at least sometimes, once it works and another time it doesnt. i dont really care since im just using another port and dont use keybot anyways.
about the sata ports, i dont know.
but hardware m.2 raid does not work on this board due to limitation on x99 chipset
Szaquak
This is long and more complicated issue tat You tought 😞
https://rog.asus.com/forum/showthread.php?79321-Asmedia-USB-Host-Controller-Was-Not-Found
ayman_abm
how to fix all these issues? I dont want to RMA...
