Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    ROG Member Array
    Jan 2016
    5
    Maximus Viii USB / device issues
    Hi guys, this is my first post on this forum and Im hoping I can get some insight into my issue. Could not find anything specific to my issue.
    Built a new pc about a month ago and have been having issues ever since. The issue is that randomly hardware will stop communicating with windows. For example, if I go into device manager and scan for new devices, The "Scanning Plug and Play compliant hardware" window will come up, but will remain there. I cannot exit the app, I cant even end the task via the Task manager window. When the issue starts, programs like cpu-z and CPUID HW Monitor will crash on start and will be stuck on my screen even after I end their tasks. Also when this issue starts, unplugging a device, such as a mouse or keyboard, upon plugging back in, the device will not get power from the USB and windows will not recognize any devices connected. Another symptom is that when selecting restart or shut down in windows, the screen will go black after the "shut down" wheel animation, but the pc will not turn off so the only way to get a proper restart is to hold down the power button or press the restart button.
    I reinstalled windows 10, 4 times, with no luck whatsoever, which led me to contact ASUS about this, and basically recieved no help whatsoever except to RMA. So I RMA'd and just installed the new motherboard, reinstalled all of the drivers, and same issue and im pretty frustrated. So i belive this to be a driver issue, but I have absolutely not clue what. Any help would be greatly appreciated.
    I am updated to 1502 (lastest bios)
    and have installed all of the drivers as recommended by ASUS's website.
    System:
    6600K 4.5 GHZ
    16GB RAM @ 3200 (XMP)
    2x 250GB Samsung 850 EVO
    NVIDIA GTX 970
    if you need anything else let me know. Thanks in advance
    -Josh
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,359
    Hello zepplin1
    Welcome to the ROG forum !
    I'm wondering if your ram is on the edge of stability. When you enabled XMP did you raise the vccio and cpu system agent voltages? If not this is likely the problem. Go into the bios on the extreme tweaker tab and take a look at the vccio and cpu system agent voltages, add .02v to both then F10 and Enter to save and exit.
    I got my fingers crossed this fixes you up, give us an update after doing this and what the vccio and cpu system agent voltages are set at after raising them .02v.
    ROG Member Array
    Jan 2016
    5
    Quote Originally Posted by Nate152 View Post
    Hello zepplin1
    Thanks for the quick reply, I just used the profile provided so I assumed it would work, guess thats the lack of experience Ocing.
    Before the change:
    VCCIO = 1.160V "Auto"
    System Agent = 1.152 "Auto"
    So im not sure if that initial number is the actual voltage or is something else being applied.
    I can enter:
    VCCIO = 1.18750v (1.180)
    System Agent = 1.17500v (1.172)
    does that look right?
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,359
    Yes try those and see if it's any better.
    Technically any ram speed over 2133MHz is considered overclocked.
    If it's not any better raise them a little more up to 1.25v, you shouldn't need anything beyond that.
    I still got my fingers crossed, let me know if this helps you.
    ROG Guru: Orange Belt Array brkkab123 PC Specs
    brkkab123 PC Specs
    MotherboardAsus Maximus VIII Hero
    ProcessorIntel Core i5 6600K
    Memory (part number)G.Skill Ripjaws V DDR4 3200 32GBs
    Graphics Card #1Sapphire NITRO+ RX 480 OC 8GB
    Sound CardOnboard sound
    MonitorLG 25UM58-P
    Storage #1Samsung 850 EVO 1.0TB m.2
    Storage #2Samsung 850 EVO 1.0TB SATA & W.D. Black 2.0TB
    CPU CoolerEK Water Blocks EK-XLC Predator 240 1.1 w/push/pull add-on fans kit
    CaseNZXT Phantom 820
    Power SupplyEVGA SuperNOVA 1000 G2
    Keyboard Logitech G213 Prodigy
    Mouse Logitech G403 Prodigy
    Headset/Speakers Logitech X530 5.1
    OS Windows 10 Pro x64
    Network RouterNetgear WNDR 3700
    Accessory #1 Logitech c615 HD Webcam
    Accessory #2 Seagate Backup Desk 3.0TB
    Accessory #3 Logitech U920 Driving Force Racing Wheel/Logitech Driving Force Shifter/GT Omega Wheel Stand
    Feb 2013
    307
    Did yhttp://www.asus.com/us/Motherboards/MAXIMUS-VIII-HERO/HelpDesk/ou install the drivers and software from the motherboards dvd ? The only things you should install from the dvd is the Sonic stuff, everything else has been updated. Download the rest from this link. http://www.asus.com/us/Motherboards/...HERO/HelpDesk/ Then click on Drivers & Tools and select your version of Windows. Then download and save everything, so you can install them all.
    What version of Windows are you using ? If you're using Windows 10 one of last month's patches caused issues with various drivers. They put out a fix for it in yesterdays updates. Run Windows Update and install updates, until none are found. You may have to do this a few times. Ig you're using Windows 8, 8.1 or 10, all open the Windows Store and click on the icon at the top that looks like your user account picture and click on Downloads and updates and install any it finds there.
    Then proceed to update your video card drivers, printer drivers, etc. Search each company of your devices for new drivers.
    P.S. Never unplug your keyboard, mouse or monitor, while Windows is running. Windows won't work without them plugged in. Only unplug external hard drives or flash drives.
    brkkab123 PC Specs
    MonitorLG 25UM58-P
    Feb 2013
    307
    Also, install the newest uefi update. Disable your antivirus while installing it or any drivers. The easiest way to install uefi, is through AI Suite 3's EZ Update and just point it to the uefi update you downloaded. Then restart your pc when it tells you to and go back in the uefi, select optimized defaults, then enable XMP for your ram and follow the previous instructions for the 2 voltages and press F10 to save your changes and go into Windows. Once in Windows, re-enable your antivirus and see if your pc runs better and post back here.
  7. #7
    New ROGer Array
    Mar 2016
    2
    I'm having USB issues too. It won't recognize new devices like my phone or usb microphone. Really frustrating. I've updated bios and all other things.
  8. #8
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,255
    Quote Originally Posted by Digitalsoju View Post
    If you have any of the ASUS programs installed, try uninstalling them for now. Also check inside the BIOS to make sure the USB controller is enabled.
  9. #9
    ROG Member Array
    Jan 2016
    5
    Okay so PC was running fine after the .2 change but happened again today gonna try the 1.25V. Couldn't even uninstal the AI suite
    Edit:
    AI suite is now stuck telling me that i need to restart in order to finish installation. I cannot run it to repair, cannot run uninstaller. Also had the same issue when updating an nvidia driver, install wouldnt finish and had to hard restart my pc. I cant find anything on the internet regarding this issue. It must be something simple, so frustrating.
  10. #10
    New ROGer Array
    Mar 2016
    2
    Quote Originally Posted by Chino View Post
    I don't think the problem is with the USB controller. It will recognize the device (sound plays each time a usb device is inserted or removed), but then it won't properly configure it.
    The strange thing is the first time I installed everything, I didn't have this major issues. It recognized my phone, it recognized my usb mic. I thought initially it might have been a problem with my mic, but it works on my laptop which has windows 10 and also on my friend's mac.
    Then I bought a new graphics card (geforce gtx 970) so I did a fresh install of windows and upgraded to the latest drivers and software. Now it won't recognize my mic
    and it had trouble recognizing my phone. They come up under device manager, but they just don't get configured properly. I've tried to reinstall the drivers so many times.
    I've tried to roll back on drivers, tried to uninstall asus software, tried to do another reformat, nothing has worked. This is by far the buggiest motherboard i've ever purchased.
    At least the front headphone jack works now ...
Tags for this Thread
