Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    ROG Guru: White Belt Array Quadrider10 PC Specs
    Laptop (Model)Asus G751JY
    MotherboardAsus
    Processor4720HQ 3.6GHz
    Memory (part number)GSkill 16GB DDR3 2133MHz
    Graphics Card #1GTX 980m
    Monitor1080p IPS G-Sync
    Storage #1SanDisk 128GB PCIe SSD
    Storage #2Hitachi 1TB 7200RPM
    Keyboard ROG
    Mouse Logitech G500
    OS Windows 10 x64
    Mar 2016
    83
    Nvidia Control Panel V-Sync issues
    whats up guys?
    so i jst bought this laptop, got everything updated and installed, and all is good. however, in nvidia control panel, my vsync option in global settings keeps reseting its self to "on" instead of what i put it at which is"use app preference". ive tried clean installing the driver 4 or 5 times with DDU and still no luck, ive also tried setting the setting in nvidia inspector and again, still no luck. it just keeps changing bacl to on. how would i go about fixing this so my setting sticks? idk what is even causing it to reset. i go to play one game, exit out, then another, when i exit and check it, it gets reset to on. also, i think after reboots, it resets its self again. i have the latest version installed.
    also, just a quick question instead of making another thread. is it possible to overvolt this GPU at all?
    It's all for ****s and giggles, until someone giggles and ****s.
    ROG Guru: Yellow Belt Array antoine52200 PC Specs
    Laptop (Model)G751JT
    MotherboardASUS
    Processori7-4720HQ OC at 3.8Ghz
    Memory (part number)16Go 1600Mhz OC
    Graphics Card #1NVIDIA GTX 970M OC
    OS Win10 64bits
    antoine52200's Avatar
    Jul 2015
    241
    Unninstall your driver with DDU and do a clean install it should fix the problem!
    MotherboardAsus
    Keyboard ROG
    Mouse Logitech G500
    OS Windows 10 x64
    Mar 2016
    83
    I have 3 or 4 times. Still has the issue.
    ROG Guru: Orange Belt Array DeltaActual's Avatar
    Dec 2011
    34
    357
    you've bought which model? G-SYNC on board?
    GL704GW
    MotherboardAsus
    Keyboard ROG
    Mouse Logitech G500
    OS Windows 10 x64
    Mar 2016
    83
    yupp G751JY WX
    Jan 2016
    37
    140
    Which drivers you try to use ? Which OS ? can you take a capture of the control panel (include the V-sync part).
  7. #7
    MotherboardAsus
    Keyboard ROG
    Mouse Logitech G500
    OS Windows 10 x64
    Mar 2016
    83
    Quote Originally Posted by nab View Post
    im on Windows 10 with driver version 364.51 (latest WHQL) THe notebook has an i7 4720HQ and GTX 980m. that vsync option keeps defaulting to "on"
  8. #8
    Jan 2016
    117
    I believe the G-sync setting is the culprit here. I was experiencing the same problem until I switched G-sync to "full screen & windowed mode". But I've came to realize G-sync works a lot better with G-sync and v-sync on in NCP. And v-sync off in-game... Also I hope you change your power management setting from adaptive to performance when gaming. Gave me an extra 10-20 FPS in GTA V.
  9. #9
    MotherboardAsus
    Keyboard ROG
    Mouse Logitech G500
    OS Windows 10 x64
    Mar 2016
    83
    power settings in NCP?
    i still want to fix this. i like getting max FPS. rite now i have it set to full screen and window settings, vsync keeps defaulting to "on", and on nvidia inspector, i set an FPS limit to 75 FPS so i dont have to deal with the input lag. but some games i like to have full FPS and no cap like BF4.
  10. #10
    Jan 2016
    37
    140
    Sorry I completely forget about the thread and didn't look into your answer.
    Quadrider10, try to set off G-sync and check if you can set off V-sync, if it work, set back on, on G-sync.
    Since 36x... NVIDIA force auto V-sync on when you have G-sync on.
