03-21-2016 07:51 AM - last edited on 03-05-2024 10:17 PM by ROGBot
03-22-2016 09:51 PM
03-23-2016 12:29 AM
03-23-2016 05:41 PM
03-23-2016 07:57 PM
teknic111 wrote:
The fan is mounted in the basement of my case ( CaseLabs Magnum SMH10). There is absolutely nothing shorting it.
I contacted Asus support and was told that the fan extension card is not compatible with the current version of AI Suite III for Windows 10. I really find this hard to believe since the fan extension card is nothing new and has been shipping with various Asus motherboards for years now. The support rep did not sound competent at all and I think he just told me this to get me off the phone.
Can someone confirm for me if this is BS or not?
Thanks in advance!
03-24-2016 07:11 AM
hiong wrote:
I'm asking about the mounting of the fan extension card, not the fans.
03-24-2016 09:41 AM
AI Suite III works fine on my Windows 10, including Fan Xpert 3 within the suite.
02-01-2017 04:12 AM
teknic111 wrote:
The fan extension card is mounted in the basement of my case ( CaseLabs Magnum SMH10). There is absolutely nothing shorting it.
Thanks in advance!
02-01-2017 07:35 AM
emsir wrote:
The Fan extension card works with or without Windows 10. There is no driver needed for the card to work or to show up in Fan Expert 3. If you have connected the fan extension card properly ( the small connector for motherboard and the molex) it should show up in Fan Expert 3. Try to pull the motherboard connector carefully out and reseat it on both ends (motherboard and Fan card). Use a flashlight to check if it's connected correct. It seems like a connection problem and by that Fan Exoert 3 can't see the fans.
As of why the Corsair fans not being rekognized could be related to bad connections. These corsair fans are 4 pin PWM. The old fan you connected is for sure only 3 pin. 1 pin on the 4 pin fan is PWM and if your connection to the motherboard is bad or not connected properly, it could be the reason.
I have the Fan extension card and 3 fans connected. All 3 fans shows up in Fan Expert 3 ( Corsair Pro 140 mm) The problem is not Corsair fans.
