Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
    ROG Member Array
    Mar 2016
    23
    Exclamation Formula : M.2 heat trapping problem?
    I was working on composing a new PC, and I completely fell in love with the formula,
    however, something is bugging me a bit.. The M.2 drive, why is it enclosed in a plastic box?
    M.2 drives are known to get pretty hot, some of them hit up to 110'C/230'F with sustained transfers.
    Wont it be problematic when you stuff it behind the armor plate of the Formula motherboard?
    Id hate to spend the extra money on an M.2, only to have it severely heat throttling all the time.
    Tech Marketing Manager HQ Array Raja@ASUS's Avatar
    Apr 2011
    161
    7,454
    If heat is a concern, you don't have to install the cover.
    ROG Member Array
    Mar 2016
    23
    It wont look pretty without the RGB LED diffuser though..
    Would it be possible to buy an additional cover piece somehow?
    If so, I wouldn't mind taking a dremel to it for a nice little heatsink hole.
    A half square inch little sink on the controller chip is really all it would need,
    but if getting a spare lid is not an option, id be scared of botching a 400 dollar motherboard. :')
    Apr 2011
    161
    7,454
    The covers are not sold separately.
    New ROGer Array
    Mar 2016
    2
    Quote Originally Posted by Sokonomi View Post
    Before you buy something. See how """support""" works when something goes wrong.
    When you are planning to buy something, every Asus"support"guy tells you are going to buy the best brand. But beware if you had a problem.
    They simply disappear, or answer "return it...".
    Just for advice
    Good luck
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,359
    According to the Samsung specs the 950 pro can get up to 70c (158F) which is pretty warm but not toasty hot. You can let the cover off as Raja suggests and have a fan blowing across it.
    I don't have one yet but I'm contemplating the 950 pro 512GB myself.
  7. #7
    ROG Member Array
    Mar 2016
    23
    Quote Originally Posted by Nate152 View Post
    70'c? Try 97'c.
    https://www.youtube.com/watch?v=d3GlInzvHr8
    Leaving the cover off seems silly, You don't buy a Ferrari and drive it around with the hood off either. With a motherboard that boasts fancy 'armor' plates and RGB lighting, looks are important and shouldn't have to be compromised in order to use all its features...
  8. #8
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,359
    Interesting, I guess it does run hotter than 70c but I haven't seen anyone on Newegg or Amazon complaining about the 950 pro running hot in the maximus viii formula, granted there are only a few reviews.
    This should make us all feel better.
    http://www.pcper.com/reviews/Storage...ling-Conclusio
  9. #9
    ROG Member Array
    Mar 2016
    23
    Basically what it comes down to is "Only use the M.2 for bursts, continuous transfers will gag it."
    But for bursts it apparently isnt so good either.
    Windows boots and game load times from a 950 pro are almost identical to 850 evo.
    http://techreport.com/review/29352/o...sds-reviewed/5
    I wanted a faster drive for unpacking archives and such, but it seems M.2 is pointless in both burst and continuous. :'3
  10. #10
    Apr 2011
    161
    7,454
    This is one of the reasons I prefer U.2 drives.
Tags for this Thread
