EVGA SuperNOVA 1000 G2 Power Supply
MITK
I have a EVGA SuperNOVA 1000 G2 Power Supply and i am setting up my Rampage V Extreme.
On the power supply it gives me an 8 pin CPU connector that breaks into two 4 Pin Female ends. Can i use that for the EATX12V_1 (B) or should i use a 8 pin to 8 pin cable (One didn't come with the PSU)
6 REPLIES 6
drop4205
Level 12
You can use that for the 8pin cpu connection. Did it come with a 4 pin to populate the 4 pin connector on board?
Maximus XI Formula, I9-9900k, Phantex Evolove X, Seasonic Titanium 850W, Custom loop PE360+SE360 Rad, G.Skill Trident Z F4-3200C14 32g, Nvidia Reference RTX 2080 TI, Samsung 970 EVO Plus 1Tb, Windows 11
memetic
Use the cables that came with the PSU.
The PSU came with:
1 x 24 Pin ATX
2x 4+4 Pin EPS12V
6x 6+2 Pin PCI-E
10 x SATA
5 x Molex
1 x Floppy
the EPS12V has an 8 pin for the PSU and the end has two 4 pins, So i need to combine the 2 4 pins for the EATX12V_1 or buy a new cable
I tired using the 2z 4Pin in the Monthboard but one side of it keeps coming up as the "clip" that holds the connector is only 1/3 of the size of the plug
drop4205
Level 12
The 2 4pins should clop together to give u 8. Upload a pic
memetic
What drop4205 said.
