Project: DOOM - ZenModz
Zenator
Hello again.
A build based on the new DOOM game.
This Build will be entered in the Cooler Master world series Case mod.
Intro:
With this build I'm not going to try and better or match any other past doom builds,
I'm just going to give my own style of the new Doom game how I see it and the only way I know how, And that is to mod the crap out of it. I hope you enjoy the ride. This build only has a 8 week life span as it must be done before the last day for entering the Cooler master world series. So I have a real lot of work to do to get it done in time.
Before we get started I would like to thank all my new sponsors for believing in me, And for all your support you have given for this new build,. It means a lot to me.
To start off here is some of the coolest gear from Cooler Master.
Pun intended. 😄
The Master Pro 5 case that will be used in this build, as well as the CM 850 PSU,
CM Silencio FP 120 PWM fans, And to top it off I will be painting a CM STORM MECH Keyboard to match the Master Pro 5 case.
I will go into more detail for each item as the build moves along.
To start of some photo, of the work I have done so far over the last week.
MR creepy well that what I call him. and for some strange reason no one I know like the look of him. not sure why.
He started off as two blocks of sign foam and glued together with a thin layer of body filler. and a rough drawing of where I think things go.
The entire build will be done all by hand or hand tools. no 3d printing or any cnc used.
Next the dremel come out to play. and some 120 grit sand paper.
So far so good. ?
Next is the Clay. Oh god now what, I'm thinking to my self! where to start ? Let me just say this is the first time I have tried doing some thing like this so it took some thinking before adding the clay.
I used ping pong balls for the eyes as they looked close to the eyes so that's what i used.
I have also started adding the space for the teeth which after doing all the top ones, i found that they where all to wide so later one I re-did them.
38 REPLIES 38
Zenator
Started adding some pins for the teeth. as well as the center bones for the eye brows
And here the inside of the bottom jaw.
Now the holes for the teeth on the bottom jaw.
Here I have cut the bottom jaw out to make it easier to work on.
More pins, And look his first tooth how cute.
That soon changed. :Paranoid:
And then there where more.
Zenator
Remember what I was saying about the top teeth holes fix now.
starting to add more detail now. and have fitted the bottom teeth back.
Here I'm adding the gums hanging off. Should look good when painted.
Zenator
Case Striped down to be painted.
And back into shape.
Some mesh for the hand that I'm going to start making.
Starting to cover the mesh and added the wire for the fingers.
Added the bends for the fingers.
More on that later on for now back to the skull.
I added a drip what should look like blood dripping once painted.
What I have done next is sprayed the skull in some high-fill 2K primmer when dry I will sand with 600 grit paper. and then I will paint the skull Bone white.
Now dry enough for sanding.
If I only know how much fun this was before. I would have been doing this years ago. Hope you all like it so far.
Daddy_arcanjo
Breath taking !!! Keep up showing us art man ... gl with the project i am loving it !!!
Weirdoutworld
YES! Incredible. Can't wait to see more of this!!!
Zenator
Cheers Guys. 🙂
Zenator
The hand is all most done, then just needs painting.
Thanks again for stopping by.
Zenator
Hi
Got some of the painting done today mostly the skin and nails on the hand.
and will do the rest in the morning.
Zenator
Hand is done.
Now back to the skull.
Thanks for stopping by.
