Help - DVD Drive
Retired
Not applicable
Need some help with my DVD Drive
G73JW - Slimline Type BD E DS4E1S
I don't normally use my optical drive and can't really remember the last time I used it.
Wanted to burn a DVD today but the DVD is not being recognised - just get the message "Insert a disc".
Listening to the drive it does spin up but the disc is not being recognised.
I tried a Music CD and Movie DVD and same result - nothing is recognised.
Also tried to uninstall the drive, rebooted and windows automatically reinstalled but same result - no discs recognised.
Any tips on what to do next?
Thanks in advance for the help.
8 REPLIES 8
dstrakele
Level 14
Does Windows Explorer fail to display files on a CD or DVD that has content written to it?
Or does Roxio CinePlayer fail to recognize the disk?
Does the solution in http://support.microsoft.com/kb/982116 resolve your issue?
G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
Kipper
download ImgBurn, its free
Tools, filter driver load order. capture the window and provide it in this thread.
Usually or at least sometimes it is a problem with upper filters and this will show us what you have on your system
Hi!
I have same problem. My drive worked perfectly but when I tried to copy DVD with Nero 10 something went wrong and now it's not working. I deleted UpperFilter (there was no LowerFilters) but still not working...
My computer: ASUS G74SX-1ATY
10912
Please help!
PiaRowley
Retired
Not applicable
The issue is the entire drive. It is shown on WIndows Explorer but no discs are recognised whether DVD or CD.
When I insert a disc there is no prompt to open it. When I select the drive on explorer I get a message telling me to insert a disc even though a disc is already in there 😞
Thanks for any help. I checked the microsoft link but no I don't have those KB errors.
OlegLTS
I have the same problem
Same problem here too !
cl-scott
Level 12
Have you tried deleting the upper and lower filters from the registry?
http://pcsupport.about.com/od/driverssupport/ht/upperfilters-lowerfilters.htm
