Results 1 to 4 of 4
    ROG Member Array
    Jul 2014
    7
    Maximus VIII (Formula or Extreme) - Possible Raid Configurations
    Hi to everyone!, first of all, sorry about my grammar, I'm not proficient writing in English.
    I have a question about Raid configurations in both, Maximus VIII Formula and Extreme.
    Can I configure two (02) different arrays in the Intel connectors and connect an ATAPI device? Something like this:
    • SATAG6_1: SSD 240GB, 1st member of 1st array (RAID 1)
    • SATAG6_2: SSD 240GB, 2nd member of 1st array (RAID 1)
    • SATAG6_3: HDD 2TB, 1st member of 2nd array (RAID 5)
    • SATAG6_4: HDD 2TB, 2nd member of 2nd array (RAID 5)
    • SATAG6_5: HDD 2TB, 3rd member of 2nd array (RAID 5)
    • SATAG6_6: Atapi device (Blu-Ray RW)
    If this it's not possible, someone Can tell me other options? Can I configure a RAID 1 in ASMedia connectors?, Can I boot from them? Even if not RAID is configured?
    Thanks in advance!
    ROG Member Array
    Jul 2014
    7
    ...mmmm... Anyone? an advice or something?
    ROG Guru: Yellow Belt Array Black Phoenix PC Specs
    Laptop (Model)Asus GL551JW
    MotherboardAsus Rampage V Extreme
    ProcessorIntel Core i7-5960X
    Memory (part number)2x Kingston HyperX Fury Black 16GB (4 x 4GB) DDR4-2133
    Graphics Card #1EVGA GeForce GTX 980 Ti 6GB Classified ACX 2.0+
    Graphics Card #2EVGA GeForce GTX 980 Ti 6GB Classified ACX 2.0+
    Sound CardRealtek ALC1150 (On Board Audio)
    Monitor3x Asus PA279Q
    Storage #12x Sandisk X300S 128GB 2.5" RAID0 (OS)
    Storage #24x Western Digital Black 750GB 2.5" RAID10 (Storage)
    CPU Coolerbe quiet! DARK ROCK TF
    CaseCooler Master Stacker 832
    Power SupplyCooler Master V1200
    Keyboard Asus M801 ​Keyboard -​ Red Switc​hes
    Mouse Asus ROG Gladius
    Headset Audio-Technica ATH-M50x
    Mouse Pad SteelSeries QcK XXL
    Headset/Speakers Audioengine A5+B Plus S8B Subwoofer
    OS MS Windows 10 Pro X64
    Network RouterNETGEAR R8000 Nighthawk X6
    Accessory #1 Roland UA-55 Audio Interface
    Black Phoenix's Avatar
    Sep 2015
    152
    2 different arrays you can, but you need to see what limitations your chipset may have:
    Removed from the manual of Maximus VIII Extreme:
    Intel® Z170 Express Chipset
    - 2 x SATA Express ports [gray] (compatible with 4 x SATA 6.0 Gb/s
    ports)
    - 6 x SATA 6Gb/s ports [gray] (4 ports from 2 x SATA Express ports)
    - 1 x M.2 Socket 3 with M Key, type 2242/2260/2280/22110 storage
    devices support (PCIe 3.0 x4 and SATA modes)**
    - Intel
    Rapid Storage Technology 14 supports RAID 0, 1, 5 and 10*
    - Intel
    Smart Response Technology*
    - 1 x U.2 port, supports PCIe 3.0 x4 NVM Express storage**
    ASMedia
    SATA 6Gb/s controller
    - 2 x SATA 6Gb/s ports (black)***
    * The supported functions depend on the CPU installed.
    **The M.2 slot shares bandwidth with U.2 slot and SATA Express 1 slot.
    Please refer to user manual for detailed information.
    ***These SATA ports are for data hard drivers only. ATAPI devices are not
    supported.
    The ASMedia only supports HDD/SSD and no RAID capabilities.
    So Yes, if installed in the Intel ones, it's able to. But I would do the Array of SSD and RAID0 instead of a RAID1. Speed mainly, since installation of Windows is something easy to do if you make an image from the PC after everything is updated.
    I would also ditch the Blu-Ray internal drive for an External USB Blu Ray Reader / Writer and add a forth 2TB HDD to the RAID 5 Array or add a 2TB HDD and change it to RAID10 if it was me.
    ROG Member Array
    Jul 2014
    7
    Thank You! I will follow your recommendation!
Tags for this Thread
