Results 1 to 4 of 4
    sloweb
    Guest
    Memory questions for Sabertooth X58
    I did not see a forum for the Sabertooth board, but I think this applies to all X58 chipsets.
    I am trying to choose ram for my Sabertooth X58mobo and i7-950 3.06 CPU. I am not a gamer and will not be doing any overclocking. This is a just a worksation. I have a coupla questions:
    1) As I understand it, if I am not going to overclock the cpu, then using ram that is faster than the 1366 cpu will only run at 1333. Is that correct?
    2) Since you can only use 1 DDR3-1600 dimm per channel, you can only get a max of 12GB. Is it better to go with 1333 that matches CPU and allows for 24GB if you want?
    3) What is the best way to get the Max 24GB?
    4) If I do go with 12GB of 1333, are there advantages either way of 3x4GB vs 6x2GB, cooling, speed, cost etc?
    5) lastly, proven recommendations of ram choices would be appreciated.
    Thanks for your thoughts....
    Brian@ASUS
    Guest
    moved this to the non ROG motherboard section.
    TeamROG Folding@Home Array ottoyu34 PC Specs
    ottoyu34 PC Specs
    MotherboardMaximus IX Hero
    ProcessorIntel Core i7 7700K
    Memory (part number)Trident Z RGB (F4-3600C16D-16GTZR)
    Graphics Card #1ROG Strix GTX1080 Ti OC
    MonitorLG IPS LED 27"
    Storage #1Samsung SSD 850 PRO 1TB
    Storage #2Crucial MX300 525GB SSD
    CPU CoolerCorsair Hydro H115i
    CaseCorsair Obsidian 750D Airflow Ed.
    Power SupplyEVGA SuperNOVA 750 G3
    Keyboard Corsair Vengeance K65
    Mouse Logitech G502
    Mouse Pad Razer Destructor
    Headset/Speakers Logitech Z-2300 2.1
    OS Windows 10 Pro x64
    Network RouterAsus RT-N66U
    ottoyu34's Avatar
    Apr 2010
    805
    1) Yes, you need to OC the CPU to take advantage of unofficial speeds (>1333mhz)
    2) interesting, link it if you readt that somewhere. Im not sure on that.
    3) 6 sticks of 4GB is the only way for now.
    4) The more sticks you have, the memory will tend to run hotter because of the lack of space (also depending if memory runs hot). and running 6 sticks will put more load
    on the CPU IMC, it will be a con if you OC later on.
    5) Any big brands are cool, but I suggest Corsair.
    sloweb
    Guest
    Thanks for the info....
    The single 4GB dimm per channel limitation is referenced as a intel spec in the manual:
    http://dlcdnet.asus.com/pub/ASUS/mb/...rtooth_X58.pdf See section 2.4.2
    Once again, thanks for the info...
Similar Threads
  1. How to upgrade your harddrive and memory on your G50 and 51 Series
    By Brian@ASUS in forum ROG Gaming Notebooks
    Last Post: 01-26-2018, 05:00 PM
  2. A few questions before I pull the trigger...
    By me010698 in forum ROG Gaming Notebooks
    Last Post: 11-26-2011, 03:30 AM
  3. Trying to get memory to speed up. how?!
    By LigerQ4 in forum Other Series Motherboards
    Last Post: 02-03-2011, 02:48 AM
  4. Memory Help!
    By Coamex in forum Other Series Motherboards
    Last Post: 12-09-2010, 05:24 AM
  5. ddr3 memory for Maximus III Extreme
    By jerome in forum Other Series Motherboards
    Last Post: 11-30-2010, 12:36 AM
Tags for this Thread
