Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    ROG Enthusiast Array sucka PC Specs
    sucka PC Specs
    MotherboardMaximus VIII Extreme
    Processor6700k
    Memory (part number)CMD32GX4M4B3000C15
    Graphics Card #1Strix 970
    Graphics Card #2Strix 970
    Sound CardStrix Raid DLX
    MonitorAcer XB270H A
    Storage #1Samsung 950 PRO
    Storage #2WD Red 3TB
    CPU CoolerEK Supremacy evo / 2 x EK D5 glass pump-reservoir / 2 x EK CE 420mm radiator / noctua ppc ip67 140mm
    CaseLian Li PC-D600WA
    Power SupplyCorsair AX1500i
    Keyboard Razer Blackwidow Tournament Chroma / Razer Orbweaver Chroma
    Mouse Razer Death Adder Chroma
    Headset/Speakers Edifier S730
    OS Windows 10
    Network RouterAsus AC5300
    Accessory #1 Alphacool LCD Display
    sucka's Avatar
    Mar 2015
    40
    Pch temperature improvement
    Hey,
    finally a motherboard that runs fine after having only problems on rve, the maximus viii extreme, perfect temps for vrm 30-40 degrees c, perfect cpu temp @ 20 in idle and 30-35 degrees c in stress of course after setting vcore to adaptive and even done some manual voltage settings and stock without core sync my cpu was staying at @ 1,3v an now 1.1-1.15.
    The only problem, the pch is pretty hot, boots at 40 degrees and after gaming i get 50-55 which is allot for such a cold pc with more airflow than a plane. So i want to know if anyone know if the pch uses thermal pad or thermal grease, and if it uses thermal pad what thickness and w/mk and if thermal pad is any space between radiator and chipset? because why use thermal pad even if it is low tdp, pads are for irregular surfaces. I wouldn't want to do the silly thing to make a third water loop to cool a @ 4w tdp chip. )
    Thanks!
    sucka PC Specs
    Processor6700k
    OS Windows 10
    sucka's Avatar
    Mar 2015
    40
    I know it is ok, but not by my standard, it's the hottest component in my pc, except the 950 pro ssd. )
    I found finally a review saying it uses thermal pad and thermal compound too at the same time, if that's real that's noobish, i shall use only thermal compound if there is no gap between radiator and chip and if it is a gap will use a 17w/mk thermal pad to be sure all thermal gets to the radiator so i can see normal temps by my standards.
    Because my aim and question is what it uses and what can i use so i can reduce temps, as about safeness would be safe even at 60 degrees, doesn't mean i want a cpu at 20 degrees and 40-50 pch or even 60.
    Now my aim is to find if it has a gap between heatsink and chipset, if not, best use is of compund for this use, though i understand using a pad as it lasts longer without loosing thermal conductivity but it is poorer at it than compound.
    Thanks
    ROG Guru: Orange Belt Array AKBAAR PC Specs
    AKBAAR PC Specs
    MotherboardASUS Maximus Impact VIII
    ProcessorIntel i7-6700k @ 4.6Ghz
    Memory (part number)TridentZ 3200C14 - 32GTZ 32GB
    Graphics Card #1MSI GTX 1080 Gaming X
    MonitorDELL U3014
    Storage #1Samsung 840 Pro SSd
    Storage #2Samsung 840 Pro SSd
    CPU CoolerCorsair H80i GT
    CaseCorsair 250D
    Power SupplyCorsair AX760i
    Keyboard Corsair k70-rgb
    Mouse SteelSeries Rival 100
    OS Windows 10 Pro X64
    Network RouterASUS RT-AC5300
    Dec 2013
    251
    mine goes up to 70c i think its pretty fine
    sucka PC Specs
    Processor6700k
    OS Windows 10
    sucka's Avatar
    Mar 2015
    40
    wow high ) yep know its fine still won't accept component hotter than 40 degrees il put phase changer if needed )
    leaving my joke aside, even the x99 stood at 30-35 degrees and this is so hot and allot lower tdp, need to take it lower, soon wil test if it has a gap between heatsink and chip and if not kryonaut to the rescue )
    Maybe by then nvidia will think of launching pascal finally.
    AKBAAR PC Specs
    MonitorDELL U3014
    CaseCorsair 250D
    Dec 2013
    251
    sorry to bring this old post alive again... but i thought I would like to play with PCH voltages in the BIOS to see if it would help lower the temperature without making the system unstable.
    So I changed the PCH Voltage to 0.8750 from 1.1100v and it seems that PCH temperature won't change. i still get PCH temperature around 60-70c when gaming even with case open .
    it seems so hard to lower the PCH temperature even voltage lower
    EDIT:
    I lowered the Voltage PCH even more to 0.8000v and still same temps. (IDLE TEMPS)
  7. #7
    ROG Enthusiast Array tt0ne PC Specs
    tt0ne PC Specs
    Laptop (Model)Eurocom Sky X7E2G
    MotherboardASUS ROG Maximus XI Apex
    ProcessorIntel Core i9-9900k
    Memory (part number)2x G.Skill TridentZ RGB F4-3866C18-16GTZR
    Graphics Card #1EVGA GeForce RTX 2080 Ti Kingpin
    MonitorAcer XB270HU
    Storage #1Samsung SSD 850 EVO 1TB
    Storage #2Samsung NVMe SSD 960 EVO 250GB
    CPU CoolerEKWB EK-Velocity RGB Full Nickel CPU Waterblock
    CasePhanteks Enthoo Elite ATX Super Tower (PH-ES916E_AG)
    Power SupplyeVGA SuperNOVA T2 (1600W) & eVGA BQ (850W)
    Keyboard Wooting One Analog
    Mouse SteelSeries Rival 700
    Headset Audeze Mobius 3D Head Tracking Headset
    Mouse Pad SteelSeries QCK Prism Cloth
    OS Windows 10 Professional
    Network RouterCustom Linux Box
    Accessory #1 X-rite ColorMunki
    tt0ne's Avatar
    Oct 2012
    50
    That's weird. That does suggest that there is a thermal pad and thermal grease being used... you're saying it doesn't move at all, right?
  8. #8
    AKBAAR PC Specs
    MonitorDELL U3014
    CaseCorsair 250D
    Dec 2013
    251
    Quote Originally Posted by tt0ne View Post
    yes, on idle it will never go below 50-60 even if i lower the voltages on the pch. is it because the gpu card generating heat around that area. i dont know.
  9. #9
    sucka PC Specs
    Processor6700k
    OS Windows 10
    sucka's Avatar
    Mar 2015
    40
    I even got to 70 degrees in this summer, it is very very sensible to temperature around it. The only "fix", after changing even the thermal(as the stock was not high performance one as it has low tdp), pad is simple. I remove my m2 ssd 950 pro which had really high temps and finally that titan x have arrived finally i can use my second loop and watercool my gpu's as my ex gpu's were 2 strix 970 with stock cooling and they were the harmful bunch heating it, now i have between 38 and 41 degrees no matter what, so trying to isolate it from external heat is the only solution sadly, poor design but heh, there'es always a next version.
  10. #10
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,359
    Hi sucka
    The pch temp on my maximus viii formula shows 46c idling at the desktop.
