04-18-2016 05:20 AM - last edited on 03-06-2024 02:27 AM by ROGBot
04-18-2016 07:06 AM
04-18-2016 07:44 AM
Nate152 wrote:
Hi FuzzyWolf
Welcome to the ROG forum !
It's normal for the cpu to draw a higher voltage then what you set, mine does it too.
For your ram try bumping up the vccio voltage and cpu system agent voltage to 1.15v - 1.25v. You may also need to bump up the Dram voltage to 1.40v.
Let us know if this gets your ram to 3200MHz.
04-18-2016 07:57 AM
04-18-2016 08:25 AM
Nate152 wrote:
Ram speed over 2133MHz is considered overclocked and to get it at 3200MHz you will likely have to increase the vccsa and cpu system agent voltage. It's fine to take the Dram voltage to 1.40v if need be.
The CHA and CHB at the top are the primary timings. You can enter in
Dram Timing control
16
18
38
command rate 2
Extreme Tweaker Tab
Vccio voltage 1.20v - 1.25v
cpu system agent voltage 1.20v - 1.25v
Digi+
Dram Current Capability 130%
How does she go?
04-18-2016 08:53 AM
04-18-2016 05:43 PM
Nate152 wrote:
All right
If you got it running at 3200MHz with 16-18-18-38-2T timings it sounds like you're all set. 🙂
DiGi + is found on the extreme tweaker tab, you don't need to change the Dram current capability if your ram is running at its rated specs.
Boot time will take a little longer with DDR4 memory training.
04-18-2016 07:17 PM
04-19-2016 04:13 AM
Nate152 wrote:
You're welcome
Using adaptive mode with the windows power plan set to balanced will drop the cpu voltage to .800v or there about.
Try adaptive mode and keep an eye on the cpu voltage.
04-19-2016 08:46 AM
