Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    ROG Member Array
    Dec 2010
    7
    Smile G73JW impressions after two weeks
    Hi guys
    To start with: my specs: G73jw, i7, fullHD
    The laptop is absolutely great. Wonderfull screen (damn, the pixels are a bit too small though), Splendid Mode is great; It's a definite merit.
    Sound - really suprised me, it's LOUD, with a noticeable bass! Wonderful! no cracking noises so far.
    Keyboard is great - very quiet. Touchpad's superb too, big, with multitouch.
    Performance is very good as well, i can play all my games in Full HD maxed-out.
    now the questions part:
    - i've installed win7 x64 - clean; then installed all the stuff asus put on their cd - now i have 1.5GB of ram used just after boot. normal? Doesn't seem so.
    - Had nVidia 259 drivers, now have 260; Still - sometimes games freeze for a second or two. Example: i launch Left 4 Dead 2 - I can play for few minutes, then i get a 10sec slideshow, then everything gets back to normal. Did you experience this?
    - The laptop isn't very loud. It cools down very quickly. I dont mind the noise during games - I dont hear it anyway. What disturbs me is the noise during office work. First of all, i have ca. 43C (111F) on CPU and 39C(102F) on GPU now (and most of the time).
    Are these high temperatures? While playing a game I get 70C on GPU MAX (after 1 hour of GTA4).
    The problem is that the laptop NEVER stops cooling itself. It's on the lowest possible fan speed (i guess) but still - it's running. The laptop is shaking ;-/ this is annoying.
    Can you determine the temperatures the fan starts working? i dont mind few C more here and there ...
    j00zl33t
    Guest
    I have 1.1GB of ram after boot. But that's because Ive disabled certain programs to run on startup. But having 1.5gb of memory being used is normal..especially for 64bit OS. I have almost double the amount of startup programs running on my PC yet on boot its only using 850mb or RAM..why? Because its on 32 bit Vista. So yeah, dont worry about RAM unless it starts shooting past 2gb for no reason.
    Your temps are good. Those are basically my idle temps, but expect an increase after a month or two. The max ive hit on games was 81c (accdng to GPU-Z) and that was a 5 second spike then dropped back down to low-70's which remains my average temps after 3-4 hrs of almost non-stop play...Yeah i game ALOT.
    Its good that the fans are quiet..i was surprised. Quiet and powerful. Cant go wrong with that..but as far as the laptop shaking? Man that weird my doesnt do that...
    ROG Member Array
    Dec 2010
    7
    Thanks for the reply.
    Shaking - if I put my hands on the laptop, i feel the fans. Or maybe the HDDs? They are 7200rps after all. I dont know. you can feel it everywhere on the laptop. It's not like a big deal, but it's noticeable. My old Vaio didnt shake at all.
    How about controlling the fans?
    Spunkgamer
    Guest
    What power mode are you in at the office? If in high performance mode try switching to office mode and turn off turbo boost for cpu. This migt let harddrives and fans spin as they cooling facter is not needed on a system that is not being used as a gaming fuction.
    ROG Member Array
    Dec 2010
    7
    I am using Power4Gear Entertainment, believing it's better (is some way) than the standard win7 moderate profile
    TeamROG Array V2-V3's Avatar
    Mar 2010
    11
    482
    Your temperatures look good, for your gaming performance issues I recomend switching the laptop into High Performance mode.
    Do you have the same fan noise and vibrations when in low power mode?
  7. #7
    ROG Member Array
    Dec 2010
    7
    exactly the same. Same shaking all the time.
    i dont want to send the laptop to the servis already, i need it to work... can i fix the issue myself?
  8. #8
    Mar 2010
    11
    482
    Remove the hard drives from the system and boot it to bios, confirm if the unit is still vibrating.
    Also, when the fan ramps up to high speed do the vibrations get worse?
  9. #9
    ROG Member Array
    Dec 2010
    7
    Well I did as you said, and I am quite suprised, because:
    - before, during and after playing a game, the vibrations didn't change too much - hardy at all! The noise - yes; vibrations - no.
    - After removing both HDDs (it says on them: seagate 500gb), and booting into bios - NO VIBRATIONS at all
    - After insering the HDDs again, and booting into bios - vibrations are back.
    So now I am pretty sure i feel the disks, not the fans!
    Well - this might be easier to cure (if it needs a cure at all - they are 7200rps after all)! Maybe i could wrap the HDDs in some vibration-absorbing material?
  10. #10
    ROG Member Array
    Nov 2010
    8
    Quote Originally Posted by wumpus View Post
    You get used to it over time.
Similar Threads
  1. Is G73JW A1 a slight Step Backwards?
    By ShadowDemon in forum G Series Gaming Notebooks
    Last Post: 06-14-2012, 04:46 PM
  2. G73JW-A1 Speaker Pop
    By alkaline in forum G Series Gaming Notebooks
    Last Post: 01-23-2011, 07:44 AM
  3. G73JW 3D VISION ERROR!!!!!!!! -.- ?!
    By MISIKEX in forum G Series Gaming Notebooks
    Last Post: 11-30-2010, 11:22 PM
  4. G73Jw Lojack?
    By James75 in forum G Series Gaming Notebooks
    Last Post: 11-01-2010, 06:49 PM
