Results 1 to 9 of 9
    ROG Enthusiast Array adambean PC Specs
    adambean PC Specs
    MotherboardAsus RAMPAGE V EXTREME/U3 EATX LGA2011-3 Motherboard
    ProcessorIntel Core i7-5930K 3.5GHz 6-Core Processor
    Memory (part number)G.Skill Ripjaws DDR4-2800 Memory - 64gb
    Graphics Card #1EVGA GeForce GTX 980 Ti 6GB HYBRID Video Card
    Storage #1Samsung 850 EVO-Series 250GB 2.5" Solid State Drive
    Storage #2Sandisk Ultra II 960GB 2.5" Solid State Drive
    CPU CoolerSwiftech H240-X 90.0 CFM Liquid CPU Cooler
    CasePhanteks Enthoo Luxe ATX Full Tower Case
    Power SupplyEVGA SuperNOVA 1000 P2 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply
    Keyboard Razer BlackWidow Chroma Wired Gaming Keyboard
    Mouse Razer Mamba Tournament Edition Wired Laser Mouse
    Mouse Pad Razer Firefly
    OS Windows 10 Pro
    Network RouterASUS AC5300
    Jan 2016
    49
    Memory QVL - do you have to follow it? A2/B2 post issues.
    Hey all,
    I'm at witts end. I've replaced my SSD, CPU, GPU, mobo (twice), sata cables and I'm still fighting a2/b2 post issues.
    I honestly can't figure out what to do at this point, except try new memory. I currently have 64gb of gskill F4-2800C16Q-32, which is not on the QVL. The 2666 variant is though.
    So if I am going to buy something new, should I stick to the QVL? Sadly those for this board aren't on Amazon. The list of supported memory for this board is actually quite small.
    Any feedback?
    Sincerely, I hate this motherboard.
    Thanks
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,381
    Hi adambean
    Do you have post issues with default settings? It looks like you are combining two 32GB ram kits which is never a good idea and is probably why you are having issues.
    How does it go with a 32GB kit installed?
    When looking at ram kits always go by the ram manufacturers QVL list, the G.Skill Ripjaws 4, 64GB, 2800MHz ram kit is listed compatible with asus x99 motherboards.
    http://www.gskill.com/en/product/f4-2800c15q2-64grk
    adambean PC Specs
    OS Windows 10 Pro
    Jan 2016
    49
    Yes, I have had on and off issues with default settings.
    I did not realize using two separate kits was a bad idea? Is there documented truth to that?
    Further, I had heard that 2666 is better for this board, any truth there?
    adambean PC Specs
    OS Windows 10 Pro
    Jan 2016
    49
    I just went to a single kit (all red slots), same thing.
    Either a2, b2 or constant start up and reboot.
    I ordered new memory, but it was a 32gb kit. Now that you've told me they should be a single kit, I need to change my purchase.
    Should I go 2666 or 2800?
    adambean PC Specs
    OS Windows 10 Pro
    Jan 2016
    49
    Ok, so ... I went back to the single kit and after resetting bios and tricking the startup to not see a keyboard (this mobo...), I'm back up and running. Reality is, no way to know if this will hold.
    Anyway, I think I have to move forward with trying new memory being that I've replaced EVERYTHING else.
    Any suggestions on a solid 64gb kit that's properly supported? Was thinking this? http://www.newegg.com/Product/Produc...82E16820231820
    Which is sad, because it's basically the same as mine, just slightly faster and a 64gb kit. Or do I save $65 and go with the 2400? http://www.newegg.com/Product/Produc...82E16820231832
    My biggest concern is that this memory is not on Asus's QVL: http://dlcdnet.asus.com/pub/ASUS/mb/...292.1461029929
    Please let me know ASAP so I can order and try to sell mine.
    Thanks
    ROG Enthusiast Array kaese PC Specs
    kaese PC Specs
    MotherboardX99 Rampage V Extreme
    Processor5820K
    Oct 2014
    25
    65
    Try running a single kit of your 2800 MHz RAM at 2666 MHz.
  7. #7
    adambean PC Specs
    OS Windows 10 Pro
    Jan 2016
    49
    Well, I am now back up and operable, with all sticks back in ... all at default. I'm getting tired of playing with the OC game and debating just leaving everything at stock. Which is obviously insanely stupid for how much I paid for this setup.
    So I guess a couple things ...
    1) Do I really need to OC my ram?
    2) Do I really need a 64gb kit vs. dual 32's?
    Thanks
  8. #8
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,381
    You only need 64GB of ram if you use programs that need that much, if you're just gaming 32GB is way more than enough even 16GB is plenty. If you can get one of your 32GB kits at 2666MHz - 2800MHz or even 3000MHz you could just do that.
    It's not necessary to overclock your ram but it's nice to get it running at its rated specs.
  9. #9
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,254
    Quote Originally Posted by adambean View Post
    Thanks
    2400MHz is the sweet spot for DDR4 in most situations. As for memory kits, get a single kit with the capacity and speed that you want.
