Results 1 to 2 of 2
    ROG Member Array
    May 2015
    8
    Dummy card for G74SX-BBK7 SD-card reader ?
    Greetings all,
    I'm repairing my G74SX-BBK7 computer. The SD-card reader is busted, and I should want to procure a small card or covering to prevent any dust intake from the
    empty slot on the bottom-right corner of the notebook's casing.
    Does ASUS supply any specific pieces for their machines? Or would I be able to order any dummy SD-card/adapter and keep it within my machine?
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    294
    7,412
    Anything OEM is almost certainly going to be more expensive than a standard SD card adapter. I would just use an SD adapter since they are cheap and plentiful.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
