Hi unix43
😄 and I recommend testing your PSU to eliminate that possibility.
The only definitive way to determine if the PSU is failing is to swap it out with a known working unit.
You may test it with a multi-meter and have all voltages within an acceptable range, however this does not account for any spikes or what happens under load.
BTW: GPU's run off a 12v rail and here is a good article:
http://www.overclock.net/a/gpu-and-cpu-power-connections
We owe our existence to the scum of the earth, Cyanobacteria
My System Specs:
MB:ASUS ROG Crosshair VII Hero/WiFi GPU:EVGA GTX 1080 sc PSU:Corsair AX-1200i
CPU:AMD R7 2700X Cooler: Corsair Hydro H115i Case: Corsair Carbide 780t
Memory:G.Skill TridentZ F4-3200C14D-16GTZR SSD:Samsung 500GB 960 EVO M.2
[/HR]
