Results 1 to 7 of 7
    ROG Enthusiast Array sigtrm's Avatar
    Feb 2012
    47
    G752VY Screen Bleed/Panel Mounting issue
    Hello,
    I have this ugly yellowish spots when display is black.
    I had panel and frame replaced becasue it was badly mounted( I just opened a box with new laptop and send it back to Asus almost same day)
    There was a space between panel and frame in bottom part of screen resulting in even bigger yellow spot.
    Right now after repair as you can see in picture I have yellow spots in bottom part very visible and slighly less visible in upper right corner.
    When I lightly touch the frame spots either disappear or are getting brighter, depends on where I put some light pressure so I assume this is mounting problem.
    Shall I send it back again? Or all G752 have this?
Name:	2016-05-05 23-11-50 +0200 (2).jpg
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,857
    I dont have any bleed problems that Ive noticed in daily operation. Then again I don't intentionally make the screen black and try to produce them either. Others have posted about screen bleed issue with all different models with the common denominator being the IPS panel. Regardless of what shows in the picture the simple fact of any separation in the panel whatsoever would prompt me to send it back. I wouldnt have been looking for a repair, I would have been after a replacement. Seems the shops they use to do repairs cause more or worse problems than the original issue. I generally go though a machine and dog the crap out of it as soon as I get it. If it fails at anything I pack it back in the box it came in and take it back to exchange for a new one. I understand that not all places have that luxury. Where I bought mine I had a full 90 days to return/exchange.
    Feb 2012
    47
    Quote Originally Posted by JustinThyme View Post
    Thanks for reply.
    Unfortunately I cannot return it to seller unless Asus states that unit is FUBAR. I sent it again, they ordered new screen again.
    In my case it is purely mounting issue, first it was defective on arrival, and after repair it was poorly mounted.
    Also I do not make intentionally screen black, I used black so I could take pictures so yellow spots are visible.
    They are much more visible in reality than on pictures. I like to use Windows black theme with black background so those spots annoy me a lot. Also in games those are visible.
    Some clarification about bleeding; bleeding occurs of course but color is in range of white bluefish, my screen is yellowish. Just use finger and apply some very light pressure on the frame near screen or on screen you will see what I mean.
    EDIT: Please check more clear picture below:
    ROG Guru: Orange Belt Array
    May 2011
    28
    392
    While its a hassle, I would keep sending it back until its fixed. Maybe ask who you can talk to at Asus Support since it wasn't fixed properly on the first repair? I wouldnt be too pleased at this point. Thats bad enough to where I would not be happy with it. I also dont have any bleeding on my display. It almost looks like over tightening or something else under the bezel, like its not fitting properly. They definitely need to fix it though. Good luck man!
    (ROG has simply become too expensive compared to the competition with same specs... )
    MSI GE75 Raider 10SGS - i7 10750H - RTX 2080 Super - 32GB Ram - 1TB WD NVMe - 2TB 960 EVO - 300Hz 17inch Display
    RETIRED: ALIENWARE R17 R5 - i7 8750H - GTX 1070 @ 1.9Ghz - 16GB DDR4 - NVMe 970 EVO 1TB - SSD 960 EVO 1TB
    SOLD: ASUS G703VI-XH74K, RETIRED: ASUS G752VY-DH72, RETIRED: ASUS G750JH DB71 , RETIRED:ASUS G74Sx DH72
    Ex-employee Array
    Jun 2020
    108
    2,154
    Hi sigtrm,
    I sent you a PM, please get back to me with your contact details.
    Thanks,
    Bahz
    Feb 2012
    47
    Quote Originally Posted by Bahz View Post
    Hi sigtrm,
    Thanks,
    Bahz
    Thank you for taking care, I replied to you via PM, I hope you received it.
  7. #7
    ROG Enthusiast Array JHR1979 PC Specs
    JHR1979 PC Specs
    Laptop (Model)ROG G752VY
    MotherboardROG Zenith Extreme
    ProcessorThreadripper 1950x
    Memory (part number)4x8GB g.skill Flare X 3200/cl14
    Graphics Card #1Gigabyte GTX 1080 G1
    Sound CardSoundblaster Audigy RX
    MonitorAsus PG348Q
    Storage #1Samsung Evo 960 250GB
    Storage #2Samsung Pro 850 250GB
    CPU CoolerNoctua NH-U14S - TR4
    CaseCoolerMaster Cosmos II Ultra tower
    Power SupplyCorsair HX750i
    Keyboard Roccat MK Pro
    Mouse Roccat Kone Pure
    OS W10 Pro
    Network RouterNetgear Orbi
    Apr 2016
    35
    I have similar issue with my 752VY, two spots on both sides of the ASUS logo, but not as bad as yours.
    One would hope that such an expensive laptop would have less problems, but i guess this is the sort of lappy that has more of everything;
    Power, mass, bells and whistles and sadly, problems.
