Results 1 to 8 of 8
05-06-2016 08:08 PM #1
nCubed PC Specs Motherboard Asus ROG Maximus VIII Hero Processor Intel Core i7-6700K 8M Skylake Quad-Core OC to 4.6 GHz Memory (part number) 16GB G.SKILL Ripjaws V Series DDR4 SDRAM 3200 (PC4 25600) Graphics Card #1 ASUS GeForce GTX 980 Ti STRIX 6GD5 Monitor ASUS VG278HE 27" Full HD 1920x1080 144Hz 2ms Storage #1 Samsung 850 EVO 250GB SSD Storage #2 Corsair Neutron XT CSSD-N480GBXTB 2.5" 480GB CPU Cooler Fractal Kelvin S24 Case Fractal Define XL R2 Power Supply SeaSonic Snow Silent-1050 1050W 80 Plus Platinum Keyboard Razer BlackWidow Chroma Silent Mouse Razer Mamba TE Headset/Speakers Sennheiser HD 598 OS Windows 10 Pro x64
- Join Date
- Sep 2015
- Reputation
- 10
- Posts
- 16
Maximus VIII Recognizes Platter Drive; Consistently Fails with SSD (SMART HDD/SDD Fai
System
- Mother Board: Asus Maximus VIII Hero (Bios 1701)
- SSD: Corsair Neutron XT SSD
- Win 7 x64 / Win 10 x64
Issue
After months of running without issue, my Corsair Neutron XT SSD stopped being recognized by my Asus Maximus VIII Hero motherboard. The specific error I receive during boot up is:
SMART detected HDD/SDD failure 1 : Corsair Neutron XT SSD
Initially, I thought the error was due to the SSD failing. Now I'm not convinced. If I go into the Bios and override the boot drive, I can successfully boot into the O.S. By override, I am seeing 3 boot options:
Boot Option #1: UEFI: HL-DT-ST BD-RE WH14NS40 (3894MB)
Boot Option #2: P1: Corsair Neutron XT SSD (228936MB)
Boot Option #3: P6: HL-DT-ST BD-RE WH14NS40 (3894MB)
- Boot Option #1 was not present prior to installing the new O.S.
- P1 is the SSD drive
- P6 is the BluRay drive
If I use Boot Option #2, I can successfully boot into my O.S. I've been unable to disable Boot Option #1 which always gives the error above.
Question: Is there some Bios setting I need to configure for UEFI enabled Bios and SSD's to successfully boot? (I'm not entirely sure, but I believe this may have started when I upgraded my Bios from 1504 to 1601)
Here are a series of images showing the original error and the Bios Boot options.
###Boot Error
###Boot Options
###Boot Options close up
###Boot Compatability Support
###Boot Secure Boot Options
05-07-2016 12:59 AM #2
- Join Date
- Sep 2015
- Reputation
- 10
- Posts
- 16
I chatted with Asus support and they insisted the SSD was defective (both SSD's). After further chatting, they suggested I disable SMART check in the BIOS... after disabling SMART check, no issues with starting/rebooting. I'll try another new SSD later, but for now, this does seem to solve the issue.
05-09-2016 03:12 AM #3
- Join Date
- Oct 2012
- Reputation
- 339
- Posts
- 15,247
Definately test your system with another SSD or test your current SSDs on another system.
05-09-2016 04:43 AM #4
G75rog PC Specs Motherboard R VI Apex Processor I9-7900X Memory (part number) 64GB Gskill Trident Z Graphics Card #1 AMD Radeon VII EKWB water block Graphics Card #2 Waste of PCI lanes in NVME environment Sound Card Stock Monitor LG 34" Ultra Wide3440x1440 Storage #1 4ea 960 Pro 2TB, 2ea 970 Evo 2TB Storage #2 1ea 960 Pro 1 TB, 1ea 970 Pro 1TB CPU Cooler EKWB CPU, Swiftech Res/pump, 400mm Rad Case Thermaltake View 91 Power Supply NZXT Hale 90 1200W Keyboard Logitech G910 Mouse Razer Ouroboros OS W10 64 1809, 1903, Ubuntu Linux Network Router Netgear R9000 + 4ea R9000 AP's, 10 Gb Switch Accessory #1 Hyper M.2 X16 V2 Accessory #2 10GB network via Intel 550 Nic Accessory #3 2 10GB Asustor NAS 7000 series
- Join Date
- Jan 2013
- Reputation
- 13
- Posts
- 309
I use Crucial, Intel, Samsung, and OCZ ssd's in my 5 machines without any problems. Corsair is not on my personal list of quality components.
05-15-2016 05:24 PM #5
- Join Date
- Sep 2015
- Reputation
- 10
- Posts
- 16
As a follow-up. I purchased a new Samsung EVO and installed without any further issues. Using Atto Disk Benchmark v3.05, the Read/Write speeds of the Samsung EVO are just slightly slower than the Corsair Neutron XT, though in reality, imperceptible.
Also, I tried the Corsair SSD in an HP Laptop (HP Beats Special Edition 15-p071nr) and the Bios immediately reported the same error.
What's odd, is neither the Corsair nor Samsung SSD tools report any issues with the Corsair SSD; only the Bios appears to have issues.
08-06-2017 02:46 PM #6
FuturisticMC PC Specs Motherboard Asus Maximus Viii Extreme Processor Intel i7 6700K Memory (part number) Dominator Platinum 32GB (4x8) DDR4 3000MHz (CMD16GX4M2B3000C15) Graphics Card #1 Asus Strix 1080 A8G Monitor Asus PB277Q Storage #1 Seagate 4TB SSHD Storage #2 Corsair Neutron XT 240GB SSD CPU Cooler Cooler Master Hyper 212 EVO Case Corsair Obsidian series 900D Super Tower Power Supply Corsair AX1500i Keyboard Logitech G710+ Mechanical Gaming Keyboard Mouse Evga Torq gaming mouse Headset Astro A50 Mouse Pad ROG Sheath OS Windows 10 64bit Accessory #1 Logitech G27 Racing Wheel
- Join Date
- Aug 2015
- Reputation
- 10
- Posts
- 50
i have that exact same drive and im getting the same problem, im about to disable smart to see if that helps
08-07-2017 01:51 AM #7
ondersma80 PC Specs Motherboard Maximus VIII Hero Alpha Processor i7-6700K Memory (part number) F4-3000C15D-16GTZ Graphics Card #1 EVGA GTX 1070 SC Sound Card Xonar DSX Monitor PG278Q Storage #1 Samsung 960 Pro Storage #2 Assorted SSD & HDD CPU Cooler NH-D14 Power Supply Silencer MK III 850W Keyboard G105 Mouse G700S Headset/Speakers Bose Companion 5 OS Windows 10 - I moved on from the technology of the previous decade.
- Join Date
- Oct 2015
- Reputation
- 10
- Posts
- 261
The easiest explanation is the drives both have faults in the SMART data. That would seem to be ruled out by the OP trying a replacement drive. My bet: the drives have vendor-specific ID's (these often aren't seen in some programs) and the UEFI of these boards is checking those IDs for info. Those vendor specific might correspond with traditional HDD IDs and be misinterpreted as faults. You could always post the smart from a program like AIDA64 or CrystalDiskInfo.
10-19-2021 09:49 PM #8
- Join Date
- Jan 2018
- Reputation
- 10
- Posts
- 1
Where i can disable smart check on this board bios? Thanks
