Results 1 to 8 of 8
    ROG Guru: Yellow Belt Array ROG_HARDCORE PC Specs
    Laptop (Model)GX501VI Zephyrus
    MotherboardROG RAMPAGE VI EXTREME
    ProcessorIntel® Core™ i9-7980XE
    Memory (part number)64GB DDR4-4700MHz Trident Z RGB
    Graphics Card #1ROG Poseidon GeForce® GTX 1080 Ti Platinum edition
    Graphics Card #2ROG Poseidon GeForce® GTX 1080 Ti Platinum edition
    Graphics Card #3ROG Poseidon GeForce® GTX 1080 Ti Platinum edition
    Graphics Card #4ROG Poseidon GeForce® GTX 1080 Ti Platinum edition
    Monitor2X ASUS ROG Swift Curved PG348Q
    Storage #12TB Samsung 960 PRO
    Storage #22TB Samsung 960 PRO
    ROG_HARDCORE's Avatar
    Feb 2016
    8
    211
    G752 Ultimate cooling tips
    To manually Push all Fan to max press and hold [ Fn+PgUP ] and loud fan burst will start, very good for OC use and dust cleaning. To stop, you will have to shutdown the pc. No other method yet.
    will update if found any method to stop.
    idle temperature 28'C & G752VY.
    Should work on most of the ROG models. Try it out
    ROG Guru: White Belt Array Gustave PC Specs
    Gustave PC Specs
    Laptop (Model)Asus ROG G703GXR - 9980HK - DDR4 64GB - 3x nm2 SSD 1.5TB [RAID0] - 1x SSD Samsung 2TB
    MotherboardAsus Rampage IV Extreme
    ProcessorCore i7 4960X
    Memory (part number)32GB Corsair CMT16GX3M4X2133C9
    Graphics Card #1EVGA GFX Titan
    Graphics Card #2EVGA GFX Titan
    MonitorDell S2340T
    Storage #18x Crucial RealSSD C300 @ 3Ware 9750-8i RAIDCntrlr 1.85 TB
    CPU CoolerCorsair H100i
    Power SupplyCorsair AX1200
    Network RouterDraytek Vigor 2960 / Ruckus Wireless ZD1200
    Gustave's Avatar
    Aug 2012
    13
    122
    Quote Originally Posted by ROG_HARDCORE View Post
    Thanks for tip. Didn't work a first for me but the fans kicked in after 10 sec or so.
    Jan 2015
    107
    Is this for the g752 only? I don't seem to be able to do it with the 751
    Laptop: G751JL
    Processor: i7-4750HQ
    Graphics Card: GTX 965M
    Memory: 8 GB Samsung (stock)
    Storage #1: Samsung 850 EVO 250gb
    Storage #2: 1 TB 7200 rpm (stock)
    OS: Windows 10 x64
    Feb 2016
    8
    211
    Tested on some newer G series such as G502VT, G752 series. but not sure older sill models.
    On desktop or in gaming center, press and hold [ Fn+PgUP ].
    ROG Enthusiast Array
    Feb 2016
    35
    FN keys
    I can confirm this works too. G752VT DH72. However I'm not sure if its working after pressing and holding for 10 seconds or more or it just take a long time to speed up the fans. Can anyone confirm what the actual sequence is to activate the fan to max? And if someone figured out what how to return fan to normal without shutting down?
    BTW another tip.
    FN + up arrow key = stop
    FN + down arrow key = play pause
    FN + right arrow key = next track
    FN + left arrow key = previous track
    Worked with Mediamonkey and VLC player.
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,855
    Or download and install notebook fan control
    https://rog.asus.com/forum/showthrea...r-fans-G751-JY
    If you dont want to do all the customization you can use manual and the profile for ZENBOOK UX32VD so it gets both fans then just move the slider.
  7. #7
    ROG Member Array
    Feb 2016
    5
    Hey I've also found out that pressing Scroll Lock key on an external keyboard will make the fans run at max speed. In G752 Fn + Page Up also register as Scroll Lock but I can't stop the fan spinning from max speed once Scroll Lock is pressed. It's kind of annoying that I need to restart the laptop every time to reset the fan speed. Hopefully someone can find the manual way to stop the fan from spinning at max speed without restarting the laptop.
  8. #8
    New ROGer Array
    May 2017
    1
    Any solution to turn-off fan after press SCRL LK?
    I've an external keyboard that turn on backlights with SCRLL LK button, i can't use it because fans start rotate at maximum speed
