Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    ROG Member Array
    Apr 2016
    6
    G550 laptop and flashing battery indicator after heavy games
    Hello, I have about 2-3 years old g550jk laptop and it has something in battery.
    It works just fine, except if I play some heavy game like wow legion alpha or fallout 4, because after those games, my battery led is just flashing and its status is "xx% available (plugged in, not charging)" And that % number never chance after that, its stay on one number were you charging or not.
    I can still use it, but sooner or later it will crash because low battery, mostly at night when its on standby without power.
    and after that, led is not blinking and it will charge normally.
    Other option is to do bios update, that removes battery blinking as well and charging continues.
    Blinking is about 1,5-2 blinks per second, and it is on if computer is powered or not, running or standby. only complete shutdown removes blinking (until I restart, of course)
    Computer is:
    g550jk, 15" i7 4710HQ, 750GB hybrid disc
    installed windows 10, that blinking newer happened in W7, but that might be just a luck. and I don't think it started right after that.
    Somehow it doesn't seem to be battery problem, because why would battery refuse charging before it has emptied completely? Tho, I hope its just battery, that's easy to replace and computer is still somewhat good
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,858
    Its normal for the battery to discharge somewhat during intensive applications whether it be games or not. When the brick cannot supply 100% of the needed power it draws that energy from the batteries.
    Its also normal that is you do this for extended periods of time and the battery and machine becomes hot for it to not charge due to thermal limitations and resume normal operation after it cools down.
    ROG Member Array
    Apr 2016
    6
    Well, yeah... but is it normal that computer wont recharge battery at all after heavy games? Led just blink for ever. First time I look that blinking about 2 weeks. (that means laptop is using power for running, otherwise it wouldn't run that long)
    Today I had to let computer on bios screen till it shutdowns it self, after that it starts recharge. (Like I say at earlier post) and so disappeared that annoying blinking.
    btw, reason I left it on bios is that it wont lost any data from HDD, but if you let computer reboot on windows running, you might lose something.
    ProcessorI9 9940X
    OS Win10 Pro 1809
    Nov 2013
    144
    3,858
    Does it do this when you don't use resource intensive applications?
    ROG Member Array
    Apr 2016
    6
    Nope, every time some game has triggered it. Heat maybe?
    and some ½h -1h gaming doesn't seem to trigger it.
    ProcessorI9 9940X
    OS Win10 Pro 1809
    Nov 2013
    144
    3,858
    Im sure its heat related as to why it wont charge. Question is why it wont iniate a charge after it cools down.
    Are you set for fast boot?
    If so then that could be the culprit as all it does is save the current kernal and drivers to hiberfil.sys file then reload them which puts you right back to where you were and does not do a full shut down.
    Nest time shut it down, then hold the power button down until you see the leds flash and the light on the power button go out. Then initiate a boot normally by just a momentary push of the power button.
  7. #7
    ROG Guru: Green Belt Array
    Mar 2015
    8
    513
    i think battery is near dead... please look at wear level
    at the moment when blinking begin there is no charging and sometimes the battery is empty but the icon still show fully charged or so!
    only thing i can do is hard reset,blinking ends and battery begin charging.
    its all only temporally because after hours the blink begin again and so on!
  8. #8
    ROG Member Array
    Apr 2016
    6
    Well, my battery reports tell me stuff like: http://mlp.helvetti.org/battery.html I have no Idea what that does mean ;D
    and about that 'hard reset' how you do it? Or is it same that you just let it go empty.
  9. #9
    ProcessorI9 9940X
    OS Win10 Pro 1809
    Nov 2013
    144
    3,858
    Quote Originally Posted by zaleo View Post
    You battery report looks fine. If it was about shot you would never get to 100% charge.
    Did you try what I posted above with holding down the power button until all the lights flash and the power LED on the button goes out followed by a normal momentary depression of the power button and booting as normal?
  10. #10
    ROG Member Array
    Apr 2016
    6
    Yeah, pressing power button worked. Good, now I don't have to do complete discharge if I want to be sure that battery is charging.
    But question is... how to check is it faulty battery or computer? 'C41-N550' battery isn't that cheap to buy just for testing
Tags for this Thread
