Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 39
  1. #21
    ROG Guru: White Belt Array rocafella1978 PC Specs
    Laptop (Model)DELL XPS SE, i5-5200U, 8GB, 256GB, QHD
    MotherboardAsus Rampage V Extreme/U3.1
    ProcessorIntel Core i7-5930K
    Memory (part number)128GB G.Skill Ripjaws V F4-3000C14Q2-128GVKD
    Graphics Card #1Nvidia GeForce GTX TITAN X 12GD5 12GB
    Graphics Card #2Nvidia GeForce GTX TITAN X 12GD5 12GB
    Sound CardAsus Xonar DGX and Onboard
    MonitorASUS ROG Swift PG348Q
    Storage #1Samsung 950 PRO MZ-V5P512BW NVMe M.2 512GB SSD
    Storage #2Samsung 850 PRO MZ-7KE512BW 2.5" 512GB SSD
    CPU CoolerNoctua NH-D15
    CasePhanteks Enthoo Primo Special Edition (Green)
    Power SupplyCorsair AXi series AX1500i
    Keyboard Razor BlackWidow Chroma
    Mouse Razor DeathAdder Chroma
    Headset Sennheiser G4me One Black
    Mouse Pad Razor Vespula
    Headset/Speakers Logitech Z906 5.1
    OS Windows 10 Pro 64bit
    Accessory #1 Samsung 850 EVO MZ-75E250B/AM 2.5” 256GB SSD
    Accessory #2 Asus ODD BC-12B1ST/BLK/B/AS
    Accessory #3 Nippon Labs USB 2.0 Internal Memory Card Reader ICR-BB
    Apr 2015
    103
    hi Arne, just curious, i have 2nd board with 1501 BIOS on it, never changed BIOS, looked it also, that one is also all grayed out/ can't do anything in the list. (DRAM Timing Control)
    as for the board which now FLASHBACK to 2101, same thing again, can't change anything in DRAM Timing Control.
    *** UPDATE *** CMOS CLEARING DID THE TRICK, now i can make changes!
  2. #22
    Apr 2015
    103
    Quote Originally Posted by Arne Saknussemm View Post
    Clear CMOS
    In Extreme Tweaker Tab
    Set AI Overclock Tuner to "manual"
    Set Dram frequency to 3000
    Go into DRAM timing control and set primary timings for your RAM...( will look like 15-15-15-35 for example...read that off the sticks themselves leave the rest on auto)
    Go into Digi+ and set DRAM current capability to 130% and phases to extreme for channels AB CD
    Set CPU system agent voltage (vccsa) to 1.25
    Set CPU input voltage (vccin) to 1.9v
    Set DRAM voltage (vdimm) to 1.36 or 1.375 for AB/CD
    Set CPU spread spectrum to disabled
    F10 save and exit and see if that boots and if it is stable.
    EDIT:
    In Dram timing control you can also try setting "rampage tweak" at the top to "2"
    hi Arne, i have now set 14-14-14-34, command rate=auto
    then DRAM FREQUENCY = DDR4 3000
    should i put for DRAM VOLTAGE (CHA, CHB) and DRAM VOLTAGE (CHC, CHD) = 1.35 ?
    ---> what is BCLK?
  3. #23
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    481
    13,436
    Quote Originally Posted by rocafella1978 View Post
    Yay!....LOL
    Yep...and if that doesn't work try a bit more..like 1.36 1.365...1.375
    BCLK is baseclock...you should not have to touch that...should be 100
  4. #24
    Apr 2015
    103
    Arne, out of curiosity, why do we set the voltage higher than the manufacturer states @1.35V? (really out of interest to understand, not to bother...)
    PS: if doesn't boot or not stable, just go back to "F5 defaults"? yes? and using CLEAR CMOS button?
  5. #25
    Apr 2012
    481
    13,436
    That is a very big subject...Raja went over some of it here https://rog.asus.com/forum/showthrea...o-Overclocking
    Basically you are overclocking and in overclocking there are no guarantees. The manufacturer's stated voltages are a guide let's say...around which you will have to tweak and tune.
    Yes, if it doesn't boot either clear cmos or use safe boot button to go back into bios and try other settings...
  6. #26
    ROG Guru: Yellow Belt Array vmanuelgm's Avatar
    Sep 2013
    20
    204
    Hey Arne, 3000 with strap 100 can be a bit difficult for a H-E processor imc.
    I'd rather try 2933 or 3200 via 100:133...
    Omega, 7980xe, G.Skill 3600, 2080Ti, SM951 256, 960 EVO 512, 860 EVO 1TB
    Intel 750, WD SN750 Black, 840 Pro, 2xSkyhawk 4TB, 7200.14 2TB, BDR-207EBK
    EVGA T2 1600, Silverstone TJ11, Custom LC. @Acer Predator x34
  7. #27
    Apr 2015
    103
    (out of curiosity) 1) would it be less complicated if I had the CPu -->*i7-6850K? with my 128GB @3000Mhz RAM?*
    or 2) is it maybe the "easiest" solution for me, to go simply with 64GB @2133Mhz RAM with my already owned CPU->i7-5930K?
    (since i am not as tech savy as so many are and am not going to be overclocking)*
  8. #28
    Apr 2012
    481
    13,436
    Probably yes. The 6xxx processors have a stronger memory controller.
    Why...did none of that work?
  9. #29
    Apr 2015
    103
    Question
    so here are the results. with the initial settings, system boots and goes into windows, as soon as I start anything or touch anything after LOGIN (only thing successful) it gets BSOD.
    also noticed the following after BSOD, went into BIOS to change voltage, and in overview noticed RAM amount lower than 128GB. (although with default settings RAM is correct always at 128GB)
    when I entered DRAM Voltage to 1.375, motherboard would get stuck on QCODE#60, but there is no guide nor manual for what the QCODES are...so no clue what QCODE#60 stands for. had to clear CMOS and set all to default again F5.
    QCODE#60 after this and black screen, had to clear CMOS.
  10. #30
    Apr 2015
    103
    Question
    after clearing CMOS, overview:
    BIOS details:
    and found this SPD INFORMATION, which shows exactly the same for every RAM stick:
Tags for this Thread
