Results 1 to 7 of 7
    ROG Member Array superjonbon's Avatar
    Dec 2013
    21
    ASUS ROG SWIFT PG278Q problem
    [LEFT]Hello just wanted to see if anyone else is having this similar problem with ASUS ROG SWIFT PG278Q. I recently purchased a PG278Q and I love it
    but I'm having a problem. I was running the "Heaven Benchmark" the other day and I noticeed a "screen tear" at the top only (this happens in games as well).
    I searched on line about this problem and found nothing. I have G sync on in Nvidia control panel so I dont know why this is happening. Any help would be
    appreciated. Thankyou
    specs include:
    I7 4770k
    maximus VI Hero
    GTX 780ti
    ROG Guru: Green Belt Array grassy PC Specs
    grassy PC Specs
    Laptop (Model)ASUS
    MotherboardRAMPAGE 4 BLACK/RIG 2 RAMPAGE FORMULA
    Processor3960X/ RIG 2 4820k
    Graphics Card #1ASUS GTX 980 TI STRIX OC
    Graphics Card #2RIG 2 GTX 690 SLI
    Graphics Card #3RIG 2 GTX 690 SLI
    Sound CardAUZENTECH 7.1 XFI DTSMA
    MonitorDELL U3011/RIG 2 VIEWSONIC MONITOR
    Storage #1480GIG/360GIG/250GIG SSD
    Storage #2RIG 2 180GIG SSD
    CPU CoolerHEATKILLER PRO WATERBLOCK/RIG 2 CORSAIR H105
    CaseIN-WIN 909/1 COOLERMASTER WHITE STRYKER CASES/IN-WIN 909
    Power SupplyCORSAIR AX1200/ RIG 2 CORSAIR HX750
    Keyboard 2 G19'S
    Mouse 2 G9 LASER
    Mouse Pad RIG 2 STRYK X
    Headset/Speakers RIG 2 TWO B&W COMPUTER SPEAKERS
    OS WIN 10 HOME/RIG 2 WIN 7 PRO
    grassy's Avatar
    May 2012
    65
    612
    Quote Originally Posted by superjonbon View Post
    specs include:
    I7 4770k
    maximus VI Hero
    GTX 780ti
    If you have another monitor then try it and make sure if its coming from the monitor. You need to narrow down your culprits and isolate the problem.It might even be a driver that is causing the problem as you can always do a clean install of the latest driver.If you have another video card then try it.If it is your monitor then i would suspect that the problem will only get worse so best to sort this out early on especially if you have to send it back.If it is less than 3 months old then i would expect a replacement.Make sure you are not overclocked and all settings are stock as then you can rule out a settings problem when checking the issue.If you have stutter also its most likely a driver issue as nvidia's drivers of late have been dodgy for some people. Their latest is supposed to be ok though.I am using 362.0 and having no problems.I think the latest is 365.19. Oh and check you connection cable.
    FAME IS A MASK THAT EATS INTO THE FACE
    Dec 2013
    21
    ok Thank you for the input ill look into this and check
    Dec 2013
    21
    ok... reinstalled the driver (365.19) and nothing is overclocked but it still continues. I don't have another monitor or gpu at the time but I will check when I can borrow them. I did
    disable G sync and instead enabled V sync and stuttering happens but not the tear at the very top of the screen like when G sync in enabled. I did cap the frame rate just to make sure
    using EVGA precision X so its not jumping around. Still getting the same result.
    grassy PC Specs
    Laptop (Model)ASUS
    Keyboard 2 G19'S
    Mouse 2 G9 LASER
    grassy's Avatar
    May 2012
    65
    612
    How did you go mate, did you sort it out.
    New ROGer Array
    May 2016
    1
    I have 3 of these and none of the problems you seem to be having.
    Have you changed any of the monitor settings? Have you also tried setting it back to factory default?
  7. #7
    Moderator Array
    Jun 2016
    241
    specs include:
    I7 4770k
    maximus VI Hero
    GTX 780ti
    Hi superjonbon,
    Can you please kindly advice:
    1. Which resolution you are working with?
    2. If the monitor happened to be connected via a converter? Or was this a straight DP to DP connection?
    3. What options have you change from the Nvidia driver default?
    Please kindly advice these details to enable us to help you.
