Results 1 to 4 of 4
    ROG Enthusiast Array michaeldowns's Avatar
    Jul 2013
    35
    AISuite 3 - TPU Using Adaptive VC - How To??
    Hello,
    I have a previous Asus mobo (Formula VI) that used a previous version of AISuite. In that previous version, I was able to set an adaptive voltage profile to do O/C testing and etc. I found this very useful and one major reason to use an Asus mobo in this new build.
    How can I do so in AISuite 3? That feature seams to be removed in the most current version.
    Thanks,
    mdd
    CPU - Intel I7-6700K - OC to 4.60 GHz
    Motherboard - Asus Z170-PREMIUM
    Memory - G.SKILL Ripjaws V Series 32GB (2 x 16GB) DDR4 3200 (PC4 25600) (F4-3200C14D-32GVK)
    Graphics - Gigabyte GeForce GTX 970 G1 Gaming 4GB GDDR5
    O/S SDD - Samsung 950 PRO Series 256GB PCIe NVMe M.2
    Data HDD - Seagate 4TB SSHD (Solid State Hybrid Drive) SATA 6Gb/s 64MB Cache (ST4000DX001)
    ODD - Pioneer Blu-Ray Writer (BDR-2209)
    Liquid Cooler - Enermax Liqmax II 240 (ELC-LMR240-BS)
    Thermal Compound - Cooler Master ThermalFusion 400 High Performance (4G RG-TF4-TGU1-GP)
    PSU - CORSAIR HXi HX1000i 1000W Platinum Certified, Full Modular (CP-9020074-NA)
    Chassis - Cooler Master Silencio 652S - Silent Mid Tower (SIL-652-KKN2)
    O/S - Win10 Pro x64
    ROG Guru: Orange Belt Array geneo PC Specs
    geneo PC Specs
    MotherboardMaximus X Code
    ProcessorIntel 8086K @ 5.1Ghz
    Memory (part number)32 GB (2x16) G.Skill TridentZ RGB 3200 MHz CL14 @ 3600 15-16-37
    Graphics Card #1Asus ROG Strix 2070 Super A8G
    MonitorEIZO Coloredge CG2730 and Dell
    Storage #1Samsung 512 GB 960 Pro
    Storage #21TB 850 x 1 TB 860 EVO RAID0, 6 TB WDC Black HDD
    CPU CoolerNoctua NH-D15 Chromax
    CaseFractal Design R4 w/ tempered glass
    Power Supply750W Seasonic Prime Ultra Titanium
    Keyboard CM Quickfire Rapid TKL
    Mouse Logitech G305
    Headset Bose
    Headset/Speakers Vanatoo T1, ML Dynamo 300
    OS Windows 10 Pro X64
    geneo's Avatar
    Feb 2014
    27
    371
    You men under the TPU tab there is n Adaptive radio button for CPU Core Voltage? There should be One User (manual) and adaptive.
    Jul 2013
    35
    Right. There is no Radio Button.
    [ATTACH=CONFIG]57519[/ATTACH}
    geneo PC Specs
    Mouse Logitech G305
    Headset Bose
    geneo's Avatar
    Feb 2014
    27
    371
    Weird. I have a 4790k, but I doubt it is an issue of CPU generation. More like Motherboar BIOS.
    I'll poke around and see If I can reproduce that wit BIOS settings.
    EDIT:
    On second thought, I don't think there are any BIOS settings that would prevent AI suite to not give you the option to use adaptive mode. It must be the software version or BIOS firmware.
Tags for this Thread
