PCI Simple Communications Controller Driver
memetic
I have a PCI Simple Communications Controller that Win 7 says I am missing the driver. I have two external drives plugged into the PCI USB 3.1 that came with the MB and they are not showing up. That lead me to believe it is the USB 3.1 that is the problem. I downloaded the latest driver from ASUS site. When I installed it said I already had the driver. So, I selected repair. It is not working still. I tried using Device Manager and browse to driver, nothing.
Does anyone know the problem is?
Thanks.
17 REPLIES 17
memetic
OK, I got the driver issue sorted, but the USB 3.1 is not working. I plugged several different things in and none were detected. Any ideas please?
Thanks.
memetic
ASUS Rig:
Motherboard model: ASUS ROG RAMPAGE V EXTREME/U3.1 LGA2011-V3 DDR4 M.2 ACWiFi USB 3.1 Type A Intel X99 eATX Motherboard
UEFI Version: 2001
CPU: Intel Core i7-5820K Haswell-E 6-Core 3.3GHz LGA 2011-v3 140W Desktop Processor BX80648I75820K
Memory kit part number (s) and amount in GB: G.SKILL Ripjaws 4 series 32GB (4 x 8GB) 288-Pin DDR4 SDRAM 2133 (PC4-17000) Desktop Memory Model F4-2133C15Q-32GRR
GPU: ZOTAC GeForce GTX 980 Ti AMP! 6GB 384-Bit GDDR5 PCI Express 3.0 SLI Support Graphics Card (ZT-90503-10P)
SSD/HDDs/Optical drives: OCZ Storage Solutions RevoDrive 350 Series 480GB PCI Express Generation 2 x 8 Solid State Drive RVD350-FHPX28-480G
PSU: Thermaltake TOUGHPOWER GRAND 80 Plus Gold 1200W Semi Modular Power Supply TPG-1200MPCUS
USB Devices (model/version number): Transcend 1TB, Toshiba 1TB
Monitor: Asus
CPU Cooler: Corsair Hydro Series H110 280 mm High Performance Liquid CPU Cooler
PC CASE IYPC Alpha-DB6 Black Acrylic ATX Bench Case Bench Computer Case for ATX/Micro ATX motherboard
Operating system: Win7 Ultimate 64bit Activated
Drivers Installed (include version):
Any third Party temp/voltage software installed: No
System Overclocked (provide details)? No
memetic
I don't mean to be impatient or ungrateful, but how come no one ever responds to my posts to help me? Am I not following some forum etiquette? I need help please.
Kotronas
Not sure but check the manual for the lanes on the pci-e when a 5820k is used. I think it cuts some lanes on some pcie and don't remember if anything else is disabled when a 5820k is used.
5820k has 28 lanes
5930 5960 have 40
Sent from my SM-N910C using Tapatalk
Hopper64
Level 15
What PCIe slots are currently populated? That may explain why the USB 3.1 card is not working.
MZ790A Bios 2002, GSkill F5-8000J3848H16GX2-TZRK, 13900KS, EKWB D5 TBE 300, Seasonic Prime TX-1600 ATX 3.0, Asus Strix 4090 w/ Optimus block, Phanteks Enthoo Elite, Asus Claymore 2, Asus Gladius 3, Asus XG349C, Samsung 990, Windows 11 Pro
I am using the following:
Slot 1 - Graphics
Slot 4 - Revo drive
Slot 6 - USB 3.1
Is that OK? Or is this the problem?
Nate152
Hi memetic
Check in the device manager, a yellow triangle beside pci simple communications controller is due to the MEI driver not installed.
memetic
Slot 1 - Graphics
Slot 4 - Revo drive
Slot 6 - USB 3.1
All the other slots are empty.
Thank you guys for replying.
Hopper64
Level 15
Instead of repairing the driver installation, can you install the Asmedia driver? I wonder if it's a driver issue.
